Fuel mods
Old Sep 29, 2014 | 11:29 PM
ThinkRob's Avatar
Default Fuel mods
Quick question: I know there's debate on whether to do the fuel pump or injectors first, but am I right in assuming that if I replace both the pump with an SL55 pump *and* the injectors with ones capable of 550cc+ that i'll have enough fuel capacity to support almost any combination of the common mods?
Thanks!
Old Sep 29, 2014 | 11:39 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Fuel mods
Thanks!
Yes, but upgrading the injectors will require scaling them which can be difficult and time consuming for a tuner. If you change to a SL55 pump, change the filter to an unregulated one and add a adjustable fuel pressure regulator.
Old Sep 30, 2014 | 02:20 PM
ThinkRob's Avatar
Ok, thanks! So I'm figuring on an SL55 pump (like this one) and a Hengst filter (0024772701)
So now I need to figure out pressure regulation.
What sort of fuel pressure do I need to run to get sufficient fuel through the stock injectors?
Old Sep 30, 2014 | 03:57 PM
Guran's Avatar
Hi ThinkRob
I have a SL55 pump, oem fuelfilter, 665 cc/3,8 bar/55,1 psi/92 % duty cycle.
No problem at all. ( BUT i have a AutronicSM4 thats controls the fuel )
I think you will bee fine on oem fuelfilter and SL55 pump and 550 cc fuel injectors.
Dont use a adjustable fuel pressure regulator. You dont need it. Oem fuel filter is 3,8 bar/55,1 psi
If it is time concuming for the Tuner. Change tuner. They dont know what there doing
Regards Göran
Old Sep 30, 2014 | 09:37 PM
Originally Posted by Guran
Hi ThinkRob
Regards Göran
Correct me if I'm wrong.....but you are running a SLK32 and not an SRT6 ?? There are a few differences between the two OEM fuel systems. SRT6 has a fuel filter with a built in regulator....SLK32 does not.
Old Oct 1, 2014 | 10:30 AM
boostmonkey's Avatar
Thanks!
Yes.
The stock fuel pump will exceed it's capacity before the stock injectors go static.
Also, more info here:
Ultimate Fuel Rail
Old Oct 1, 2014 | 09:14 PM
32krazy!'s Avatar
regulator is on the rail not the filter. both cars
Old Oct 1, 2014 | 09:28 PM
The regulator is built into the Fuel Filter on the SRT6.
Old Oct 2, 2014 | 11:07 AM
The fuel pressure regulator was most definitely built into the fuel filter on my 2003 SLK32 AMG. The only thing on the rail was a pulsation damper.
Old Oct 2, 2014 | 05:03 PM
I knew the SRT was also at the filter but I read here previously somehwere that the SLK32 was diffrent and near the fuel rail connector. Probably one of Steve's posts. LOL
Old Oct 2, 2014 | 05:10 PM
Guran's Avatar
There is no differences between SLK32 and SRT6. Same same, but different look.
Same fuel system. Built in regualtor in the fuel filter. 3.8 bar/55.1 psi
Old Oct 6, 2014 | 06:36 PM
meh03's Avatar
Are you thinking of any specific mods?
Old Oct 6, 2014 | 08:46 PM
ThinkRob's Avatar
I'm already running an Evosport crank pulley and a custom dual CAI intake setup, along with a larger-capacity heat exchanger + CM30.
I've got a conservative tune from Eurocharged on there now, but since I'm well in the safe range, AFR-wise I may have them make it more aggressive.
I'm planning on (eventually) running stacked with a 65MM or smaller SC pulley and, after that, Needswings custom manifolds (both of which I've been told will definitely require more fuel.)
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
