DIY Code 3 Intake Question
Old Aug 18, 2015 | 11:09 AM
Ralph289's Avatar
Default DIY Code 3 Intake Question
I did the DIY Code 3 Intake a while back and it sure does sounds GREAT ! BUT as I know it must be pulling in a LOT of hot air in from the engine compartment, which I know hurts performance, especially in the HOT Florida weather. When I did the mod I made a block-off plate in case I wanted to cap the opening. Thing is I made it out of 1/8" Plexiglas. I'm not sure if that is going to be strong enough. Any suggestion would it be strong enough or should I make it out of something else 1/4" Plexiglas, aluminum, steel, ?????
Also what would be good to use as a gasket (seal) between the block off plate and the intake ??
Any ideas ?
Old Aug 19, 2015 | 07:59 AM
maxcichon's Avatar
Default Re: DIY Code 3 Intake Question
I would use 1/16" aluminum and a sheet of Buna (neoprene) as a gasket.
Old Aug 19, 2015 | 08:27 AM
Ralph289's Avatar
Yes that might work.
I was thinking just use the plexiglas plate I have now but OVER the filter that is on there now and UNDER the square frame that is on there now. Just may need longer screws.
waldig
Jul 31, 2017 09:46 AM
toob
Aug 19, 2015 07:31 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
axnguyen
Jul 21, 2015 11:41 AM
waldig
Jul 20, 2015 08:10 AM
