Dyno Mode...remove ABS Plug..."testing only"
Old Sep 18, 2015 | 01:10 AM
Billy22Bob's Avatar
Default Dyno Mode...remove ABS Plug..."testing only"
Subby over at the R170 forum posted a beauty I'll have to try on the SLK32...
http://www.benzworld.org/forums/r170...l#post12808265
Old Sep 18, 2015 | 01:36 AM
4drturbo's Avatar
Default Re: Dyno Mode...remove ABS Plug...."testing only"
Wouldn't you want to disconnect the battery before removing it?
I wonder if dyno numbers would be different with this disconnected? The OP said the car felt a lot stronger.
Old Sep 18, 2015 | 08:57 AM
pioneer4x4's Avatar
On my Charger there was a trick to act like you are trying to restart the car, while driving(starter will not engage with engine running, no risk of harm). It would reset the BCM and it would detect the motion and think a sensor was out of wack, and disable all ESP and TCM. Then when you stop and restart the car, it would all go back to normal. You may only be able to pull this off on a 6sp Crossfire, since you can't turn the ignition key to start position twice, and you don't want to turn key all the way off while moving and risk locking the column (Maybe in an empty parking lot in a nice slow bend where the wheel won't center and lock).
TerryR
Dec 13, 2019 03:27 PM
Apr 28, 2016 02:04 AM
johnnycross413
Mar 4, 2016 04:49 AM
Reliableron
Oct 17, 2015 10:19 PM
Sep 28, 2015 07:40 PM
