Pulley
Old Oct 26, 2015 | 10:57 AM
Morphh's Avatar
Default Pulley
Can someone tell me if #4 pulley and #9 are the same, I need to replace tensioner pulley and dealership wants me to buy the whole tensioner it self
Thanks in advance
Old Oct 26, 2015 | 11:22 AM
Default Re: Pulley
1. what chart are you looking at ?
2. NA or SRT6 ?
Old Oct 26, 2015 | 11:29 AM
Morphh's Avatar
Default Re: Pulley
2. NA or SRT6 ?
C32 so srt 6
I don't know how to put the belt diagram on this site, they look the same idler and tensioner, but don't know. Thanks
Old Oct 26, 2015 | 12:54 PM
4drturbo's Avatar
Default Re: Pulley
dealership aka stealership.
Save picture to your computer or phone and download photobucket. Use the IMG tags in front and back of the URL address.
Never heard of the tensioner going bad, which is what is used to take the belt off. The idler pulleys and superchager bearing would be a good idea to replace. I just replaced those 3 things last week. Didn't mess with the tensioner. Unless you have a ton of miles on your ride.
Old Oct 26, 2015 | 01:03 PM
Morphh's Avatar
Default Re: Pulley
I changed idler, guide pulley, and have 65mm sc pulley all done last 5 months, car only has 60,000 miles on it, I put new belt on cause after I installed dcai from needswing I was getting belt slip.
I can actually see the tensioner moving tiny bit when car running. When car in gear it's making noise. Thanks
Old Oct 26, 2015 | 01:12 PM
cmz's Avatar
cmz
Default Re: Pulley
Pull the pulley you want to change and take it to a NAPA auto parts . I have had good luck going that route. Any auto parts store will work. they have good selections of pulleys.
Old Oct 26, 2015 | 01:17 PM
Morphh's Avatar
Default Re: Pulley
The tensioner should not move when belt is on correct, my tension moves so slightly back and forth.
Old Oct 26, 2015 | 01:41 PM
4drturbo's Avatar
Default Re: Pulley
You NEED a belt wrap kit. Especially with that smaller pulley.
Old Oct 26, 2015 | 01:48 PM
Morphh's Avatar
Default Re: Pulley
I was looking at latemodel21 wow it looks awesome
The tensioner shouldn't move back and forth correct?
Old Oct 26, 2015 | 03:03 PM
Default Re: Pulley
Thanks in advance
The tensioner pulley is replaceable on its own, dealerships like you to buy the whole assembly so they make more money.
EUROCHARGED
Nov 17, 2015 10:20 AM
Morphh
Oct 26, 2015 10:50 AM
nonamejane
Oct 17, 2015 06:00 PM
Tahoe
Oct 2, 2015 11:34 PM
4drturbo
Oct 2, 2015 12:58 PM
