about 21 psi boost
Old Jan 22, 2016 | 12:56 AM
Wolf_7's Avatar
Default about 21 psi boost
hello there, i have 18-19 psi of boost on 62mm scpuley, stock fueling system and full of modes dcai ,downpipes,82mm tb, etc.. car havre stabile 370 whp, want some info on 21 psi of boost i can do stacked pulleys but i need sl55 pump and bosch 550 injectors both are plug and play, and thats all? car will run on right afr? nothing else?
Old Jan 22, 2016 | 05:40 PM
Zoodust's Avatar
Default Re: about 21 psi boost
I have on the 185mm pulley now and run the 550 injectors, 55 fuel pump, and updated ic pump and killer chiller innercooler to battle heat soak.. all which are plug and play along with a retune. A guy around here has stacked pullies and runs super high boost. He has all the abover listed fuel mods plus other goodies
Old Jan 22, 2016 | 08:52 PM
JEFASOLD's Avatar
You will also want Robs' adjustable fuel regulator and gauge.
Old Jan 23, 2016 | 06:38 AM
Wolf_7's Avatar
thank you, but crank pulley,injectors,pump and regulator and retune isnt worth for 30 whp i think, maby i just rise the rpm to 6600? so boost will rise too ,and see afr if there will be need for fuel
Old Jan 23, 2016 | 07:06 PM
JEFASOLD's Avatar
I didn't notice a "tune" mentioned, how do you plan to raise your RPM limit? It's not as simple as you make it sound!
Old Jan 24, 2016 | 12:54 AM
Zoodust's Avatar
Im currently full bolt on and would love to get more power lol, its just the nature of the beast.. but with that being said i still personally highly disagree with the TCU mod. I dont see the positive advantage of an extra 600rpm. I see more problems then benefits coming from doing that
Old Jan 24, 2016 | 03:09 AM
Wolf_7's Avatar
yes, rise rpm isnt hard with tcu tune , its interesting if someone do that , ill think about this i just need extra 30 for 400 whp and finish my project..
Old Jan 24, 2016 | 08:17 AM
velociabstract's Avatar
I have the ECU limiter set at 6500 and HAD a TCU set to 6400 rpm on the S/W switch. Stock TCU tune in S and modified to 6400 in W. Also, it would hold the gear until you upshifted manually. The increased power from 6000 to 6300 on the dyno was 20 hp on my car. Sounds perfect. Unfortunately I couldn't enjoy the extra rpms and power because I kept hitting bouncing off the rev limiter. The only place it worked correctly was on the dyno. The TCU was from EVOTECH I believe. Perhaps if I'd had both from Eurocharged the result would've been better. I don't know. But yes, more revs = more power. How long the valve springs can handle the extra rev's is anybodies guess.
Les
Old Jan 24, 2016 | 08:36 AM
Wolf_7's Avatar
Les
in 1 2 gears it hard to shift manualy ,722 trannys have lag, but in 3 or 4 gear i its posible to shift manualy perfect on 6500 ... i just thinking about pros and cons.. rev limit its easier to do but have issues.. 2 pulleys ,injectors ,fuel pump,and remap have no issue but have to spent money..
Old Jan 24, 2016 | 10:52 AM
Squirrel Crusher's Avatar
Could you tell me more about your 82MM mod? Squirrel Crusher
Old Jan 24, 2016 | 12:41 PM
Wolf_7's Avatar
our tb is 74mm and e550 s550 models have 82 tb, they are plug and play, but instal it on our system is not esasy
DIY: 82mm throttle body - MBWorld.org Forums
FS--82mm Throttle Bodies OEM--upgrade time
this is best diy s...its shown on 113 engine but our 112 almost same , need machined more to have 82 inlet ,after instal car needs to adapt or tune tb opening angles , result is lot more cfm,wery agressive throtle response, https://www.youtube.com/channel/UCDa...fqGvKSpiWBzFdw this is my chanel and you can see in last 5 videos how car responses, the "stock"e55 in video and cl55 have 430 whp with k&n and catless downpipes, and there is ecu tuned e55 with 450 whp...watch
Old Jan 24, 2016 | 03:42 PM
Awesome. Thank you for sharring. Do you occasionally experience any engine hiccups around 2200 RPM's?
Squirrel Crusher
Old Jan 24, 2016 | 04:00 PM
Wolf_7's Avatar
Squirrel Crusher
no , everything works good .. if anyone decides do this dont do without my advice i can give more details...
Old Jan 24, 2016 | 05:32 PM
boostmonkey's Avatar
Default
A higher capacity fuel pump, 550 cc/min injectors, a retune, and intercooling upgrades are the bare minimum requirements for running stacked pulleys and 21 psi.
I would highly recommend a wideband O2 sensor to monitor the air/fuel ratio.
Insufficient fuel delivery under load can catastrophically damage an engine, so I went further than the above mods and also installed a tank to rail to tank return-style fuel system including a new filter, check valve, 8 AN supply line, modified fuel rail, adjustable regulator and 6 AN return lines.
I run 65 psi fixed fuel pressure, which @ 21 psi of intake manifold pressure is the same pressure differential across the injectors as stock.
Old Jan 25, 2016 | 02:25 AM
Wolf_7's Avatar
what brand fuel filter you use?mahle or mann? in my country mahle is from china ) im thinking go for mann
Old Jan 25, 2016 | 02:07 PM
Default
This one:
http://www.needswings.com/high-flow-...JsxGFYM.mailto
MikeBrink28
Jan 7, 2016 05:40 PM
tropixcale
Jan 6, 2016 09:18 PM
Power Sedan
Jan 4, 2016 09:38 PM
foxxfire7
Jan 3, 2016 09:09 PM
Wolf_7
Dec 30, 2015 08:17 AM
