is there anything that would keep coolant from reaching the s/c
Old Feb 1, 2016 | 11:21 AM
Mr5150's Avatar
Default is there anything that would keep coolant from reaching the s/c
Drained coolant and replaced intercooler pump because I was having issues with the supercharger turning off on the highway. Same issue I had a couple years ago when the original pump went out. I opened up what I believe to be the intercooler(lowest large hose on passenger side) and almost nothing came out. Filled it up with water to flush it and the problem persists. No cel just overheating sc. Engine temps consistent.
Old Feb 1, 2016 | 12:12 PM
Default Re: is there anything that would keep coolant from reaching the s/c
If you get air in the intercooler you may have a problem. I changed my coolant but never had a problem.
Old Feb 1, 2016 | 12:42 PM
chuK_138's Avatar
A shot in the dark....does your car have a coolant separation kit? A picture of the area below the overflow tank would be helpful btw.
Old Feb 1, 2016 | 02:30 PM
Mr5150's Avatar
No. I might add that the coolant I got out of the car was red and not green or blue :l
Its like its not pulling the coolant into that system from the engine side.
Old Feb 1, 2016 | 04:07 PM
NeedsWings's Avatar
take a picture of your engine bay and post it up here please
Old Feb 1, 2016 | 09:51 PM
Mr5150's Avatar
Old Feb 1, 2016 | 09:53 PM
Mr5150's Avatar
Sorry didnt get any of the bay just underside. Standard NW dual intake. Everything is stock and leaky valve covers.
Old Feb 2, 2016 | 10:04 AM
NeedsWings's Avatar
do you have a obd2 reader that can watch AIT?
Old Feb 2, 2016 | 10:51 AM
Is it possible that the IC is plugged up? I guess you could run water through it with a hose. Or disconnect the return line from the IC with engine running to see if there is any flow.
If there is a build up of crud in the coolant then small passages trap the crud and eventually block up solid.
Old Feb 3, 2016 | 01:39 AM
Mr5150's Avatar
No I do not.
Blue is the return correct? Where should I disconnect at? Would using some radiator flush even help in with this car? Will our heroes make it out alive? Stay tuned for the next episode......
MikeBrink28
Jan 26, 2016 03:55 PM
Crossfiren
Jan 11, 2016 12:21 PM
jmartinpadilla
Jan 8, 2016 06:30 PM
tropixcale
Jan 6, 2016 09:18 PM
tropixcale
Jan 3, 2016 11:05 AM
