Removing torque limiters, help
Old Feb 26, 2016 | 06:47 PM
Wolf_7's Avatar
Default Removing torque limiters, help
It can do by star dyagnostics,to remove torque limiters from gearbox,shifting is more faster,and timing is always in - not drops on changing gears,also throttle body not closes and boost dont drop a little bit when changing gear,did amybody do that tune?
Old Feb 26, 2016 | 08:14 PM
Squirrel Crusher's Avatar
Default Re: Removing torque limiters,help
This would be where Rudy Compart at Acceleratd Industrie specialize's. Forum member> rcompart Squirrel Crusher
Old Feb 26, 2016 | 08:24 PM
Maybe Rudy would like a trip to Georgia, the one in Europe. Tbilisi is the capital of that country. Nice trip.
Old Feb 27, 2016 | 02:28 AM
Wolf_7's Avatar
be my guest , but just want to hear how it will be safe for transmission
Old Feb 27, 2016 | 06:39 AM
Sweet2002's Avatar
Toast. So the transmission lasts the converter unlocks, shift takes place, converter relocks. This would be if the converter is locked under WOT as in an American car that will remain unnamed. I know with mine when it is about to shift if it has revved to quickly and goes a bit past the 6200rpm redline the ESP engages and I get a jolt as torque is reduced quickly and hard. I would have to look at a datalog but it is likely the boost drops off before a shift also. Wolf have you ever done stacked pulleys, not the 178/65 but something milder like the 178/70 that I have? You are looking at the odd places for finding power. Things like weight loss. Sure you could gut the car, rip the stereo, delete the AC.
I suggest you stay with the tried and proven ways to make the car quicker remembering that a high 11 is what you can expect, maybe an 11.5 with ideal track conditions and a perfectly tuned car. The unlocking/relocking, boost drop/psi up takes micro seconds. I know of a guy who controlled his converter lock feature with the OD switch so he could keep the converter locked during shifts and so far the truck tranny he had swapped in was holding up but it was still very rough on the drivetrain and remember he had put a truck tranny in his car in order to have the tranny last a bit longer than the stock one. You would likely have to sign a waiver relinquishing all claims in the tune/tranny.
Old Feb 27, 2016 | 07:19 AM
Wolf_7's Avatar
i will shot video in my friends tranny modifited car so you can see the the difference, idrive it yesterday and in gear shifts car runs forward ,i was surprised. then we race and in every gear shift hes roll from me ,we have same power its was just tranny effect, i will do that tune monday
Old Feb 27, 2016 | 10:24 AM
Sweet2002's Avatar
Where do you get this tune? The E/C tranny tune is said to still have not been perfected and they certainly would not intentionally put a tune out that would damage the tranny given enough time. Good luck and tell us more when you find out!
Old Feb 27, 2016 | 07:02 PM
JEFASOLD's Avatar
In a recent study done with the Carbon Fiber wheels on a Ford GT (I think), losing weight in the rotational parts is worth much more than just the total weight loss. Losing 5 lbs in rotational weight is like losing 100 lbs in vehicle weight. Not to mention quicker steering and shorter stopping.
Old Mar 1, 2016 | 05:39 PM
Sweet2002's Avatar
I've read a lot of weight conversions Jim but you are right, unsprung weight is where we would like to remove weight. I could not believe how heavy the stock resonator and muffler are, wow! Wheels can be very costly. Well over $1000. a set for the light weight versions. I am looking for wheels now. I want to run a 275 in the rear but need a 9" wheel with back spacing around 6.25", stock is around 6". many light weights that are reasonable are only 15".
amx1397
15
Mar 6, 2026 11:10 PM
Jun 30, 2016 08:44 AM
brandoni
Jan 16, 2016 02:27 PM
BibaResto
Jan 3, 2016 08:22 PM
oledoc2u
Dec 27, 2015 09:18 PM
