Belt tensioner
Old May 5, 2016 | 12:41 PM
dinasrt's Avatar
Default Re: Belt tensioner
Originally Posted by chuK_138
I've only ever used Gates K081145 belts. Put them on 5 different SRT-6 motors with anywhere from an OEM pulley down to a 62mm SC pulley, even one with a 178mm crank pulley...never had a problem. Four of the five had some sort of pulley saver/belt wrap kit. One LM21 BWK (me), two DIY kits (Thumper, Kim), and a NW PSK (customer). All still run the belt I put on without issue.
I hear you Chuck. This goes to show that the tensioner can do its job, even w/ slightly different belt lengths. I don't know the difference in length between the 1145 and the 1153 that I have, but even with adding the 100mm tensioner pulley to my NW's PSK to take up some slack for the 62mm SC pulley as well as adding LM21's slightly larger alternator pulley, I have a real tight fit. The tensioner slot gauge is slightly to the left of center(about 1/3 or so), and will be closer to center as the brand new belt stretches a bit. It is my understanding that the 1/2 way mark is the sweet spot for the tensioner. Somebody please correct me if that is not the case. EDIT: I just checked the packaging of my gates belt #KO81153, and it is 116 1/4" OC (overall circumference).
Dressler85
May 30, 2016 12:13 PM
JOE6C
May 26, 2016 06:16 PM
nbmason
Apr 20, 2016 07:06 PM
tillthewheelsfalloff
Apr 17, 2016 01:52 AM
dejniak
Apr 8, 2016 11:42 AM
