Leaving in 1st gear
Old Oct 12, 2017 | 09:25 AM
Ralph289's Avatar
Default Leaving in 1st gear
Is it true that if you leave with the trans in 1st gear it will upshift automatically when it gets to the redline ? What about with the TC ON and with the TC OFF ?
Old Oct 12, 2017 | 09:42 AM
Default Re: Leaving in 1st grear
Yes, ubt usually around 4700 RPM, not redline. Not sure about TC, but I don't think it matters.
Old Oct 12, 2017 | 09:50 AM
Ralph289's Avatar
Really..... only 4700 RPM seems kind of low.
Old Oct 12, 2017 | 10:07 AM
Well, I don't have the SRT6, I have an NA, maybe difference there ?
Old Oct 12, 2017 | 02:54 PM
philosophico's Avatar
SRT6 will go to redline in manual mode. Doesnt matter if TC is on or off. TC will kill power upon wheel slippage regardless.
Old Oct 12, 2017 | 03:06 PM
Ralph289's Avatar
Thanks for your info !
Old Oct 18, 2017 | 03:13 PM
Ralph289's Avatar
It's a real thrill with the TC turned off.....but the rubber smells like $$$
Old Oct 21, 2017 | 06:35 AM
stevieb's Avatar
Default Re: Leaving in 1st gear
With the Eurocharged TCU remap upshifts are higher than standard.
Old Oct 21, 2017 | 08:01 AM
daveesrt6's Avatar
I love my EC tcu tune too , its much better eh .
my Dashcommand app reports 6349rpm has been my max,
what max revs have you seen stevieb ?
Old Oct 21, 2017 | 08:09 AM
stevieb's Avatar
I believe mine to be similar Dave but to be honest haven't checked the exact numbers.
All I can say that doubled up to the new paddle shift makes for a much more pleasing driver experience.
Old Oct 21, 2017 | 07:40 PM
daveesrt6's Avatar
Stevieb,Yes, i Want those paddles shifters too , they must be alot of fun but the install scares me abit . plus im broke atm :-(
Dashcommand (or TorquePro) work well and IF you input all the cars parameters
Correctly it is quite accurate too.
On mine Dashcommand is within 5% accurate on actual fuel consumption , its 5% optimistic.
A tweak to the Brake specific and or the volumetric efficiency settings and it would probably be spot on . I havnt done that but i should.
in Dashcommand /vehicle/advanced settings i have the BSFC set at .55lb /(hp*h)
and Volumetric efficiency set at 70%
changing these two would likely alter the HP report .
I think the 378hp report i got, allthough it was on a dead flat road , a little optimistic .
I would expect about 350+ hp with the mods i have .
Ang2004
21
Aug 7, 2019 11:06 PM
RED DOG
Sep 15, 2017 09:28 AM
Trenzman
May 6, 2014 06:14 PM
pelked1
Oct 24, 2010 10:49 PM
blackcrossfire07
Mar 16, 2010 09:23 AM
