Banging noise
i just purchased a 05 SRT6 and when you start off there is a noise like something is hitting the floor board it's gets louder but at about 45. Mph it goes zaway. If you hit the accelerator passing a car it does it ago but gradually stops. I ordered a transmission mount to see if that is the issue. Today I barely pulled out and you can hear this click click clicking sound so that tells me it's in the transmission or driveshaft. Any suggestions. It has 197k miles.
Does it have aftermarket wheels ?
If so, check that the bolts in the rear wheels are not too long and getting into the parking brake stuff.
Also check the rear sway bar mounting brackets.
congrats on the new car and welcome to the forum!
sounds like the driveshaft center support/bearing. we have them on the drivetrain page on our website. very common wear item for these cars.
[QUOTE=NeedsWings;917557 sounds like the driveshaft center support/bearing. we have them on the drivetrain page on our website. very common wear item for these cars.[/QUOTE]
Rob is most likely correct,, but don't buy one off ebay they are crap. get the correct one from Needswings
takes about 20 to 60 min to replace make sure you reinstall the two halves of the driveshaft back with the notches in line (for balance.) on one half you will see two notches on the other you will see one they must be centered to each other jim
On eBay you find good and bad items, you just have to sort the wheat from the chaff. Make sure you buy quality items as you do not want to do the job twice. Do not buy parts using the Chrysler part number, most parts have a Mercedes part number which are much cheaper 99% of the time. Chrysler dealers get the parts from a Mercedes dealer add a Chrysler label with their part number on it and a large increase in the price of the item.
ShawnQ
Oct 10, 2016 09:24 PM
waldig
Jul 28, 2010 11:29 AM
Glockhit
Oct 27, 2009 07:42 AM
