Auxiliary pump for inter cooler (supercharger)
Old Jul 15, 2019 | 09:59 PM
Moparboy's Avatar
Cool Auxiliary pump for inter cooler (supercharger)
Today i try to found auxiliary pump. At the car parts store i went, they are not listed for Crossfire but they can show me something looking like it by picture.
After, i went to Chrysler dealer to ask part number. They give me 05135368AA / 05135368AB / 05135368AC.
When i enter these part numbers in internet browser, it show me the pumps but it is discuntinued.
So, my questions is: Someone have any part number to suggest from another furnisher and any idea of flowing capacities it deliver?
Also, is it a good idea, in this occasion and because i have to replace it anyway, to find pump with higher flow capacities?
Old Jul 15, 2019 | 10:23 PM
Default Re: Auxiliary pump for inter cooler (supercharger)
Try here: https://www.crossfireforum.org/forum...on-ic-pump.pdf
or try here: https://www.crossfireforum.org/forum...500-miles.html
Old Jul 15, 2019 | 11:04 PM
The Johnson pump has fell out of favour, do not buy a Bosch pump with the part number ending in 002, you want the BOSCH 0392 022 010 pump.
You can buy it from FCP Euro or NeedsWings.
Old Aug 7, 2019 | 09:28 PM
Duckthis1's Avatar
Onehundred,can you elaborate more or give me a link of the issue with the Johnson Pumps. I have a Johnson coming in the mail and hope I don't have to return it. Thank you
Old Aug 7, 2019 | 11:41 PM
I do not think it has faults, useJohnson in search and see what you find. There is a sticky on installing the Johnson pumps showing the wiring changes.
Old Aug 8, 2019 | 09:48 PM
philosophico's Avatar
Bosch pump is plug and play. You'll have to splice some wires with the Johnson pump but if your good with that nothing to worry about.
Most arent a fan of hacking up wiring thus the johnson was a no go for some.
Old Aug 10, 2019 | 09:18 AM
DualSportDad's Avatar
last time i needed to replace one i found the updated pump on amazon for under $150.
Old Aug 10, 2019 | 10:18 AM
You need Bosch pump #0392022010 NOT the one ending with the numbers 02 which is the pump fitted originally, it was found to be susceptible to early failure.
Use that number to search online for the best price, it should be around $110 to $120.
Amazon has it at $113 plus shipping.
Old Aug 13, 2019 | 03:21 PM
Fla_Xfire_SRT's Avatar
I was hoping this thread had a little more info, mostly concerning the hoses for that intercooler pump. Are there 4 hoses to the pump, 3 to the bottom and one to the top? Is there a more specific link that might have photos of the pump repacement? EDIT> Tigheds supercooler install shows a lot as well as the johnson pump install. Does the frontmost hose closest to the radiator that seems to attatch from the top on one end attach on its opposite end to the water pump? I can see one going up to the recovery tank, and two going to the intercooler coil. The fourth one is a bit of a mystery. Thanks in advance.
Old Aug 13, 2019 | 05:09 PM
The Johnson pump install shows everything more or less, one of the hoses is not used now on the (010) pump I connected the little hose to the little dummy nipple anyway, I think it was a drain hose originally on the OEM pump (02) not sure now though.
New pump part # 0392022010 they are $113 on Amazon.
Old Feb 28, 2020 | 06:00 PM
gloverSRT6's Avatar
What is the difference between the 002 and 001 pump? I bought one from Needswings and it is the 001 pump
Old Feb 28, 2020 | 06:39 PM
You want the 010 pump. The 001 is the old pump I think.
chrisp92103
Aug 4, 2016 12:14 PM
God_Likes_Tebow
Feb 6, 2013 02:31 PM
TomSRT
Dec 13, 2012 11:12 AM
PitMarshall
Jan 27, 2011 04:58 PM
MI Roadster
Other Cars Etc
Dec 13, 2004 12:28 PM
