oil filter
Old Sep 15, 2019 | 01:36 PM
Default oil filter
As a first time SRT-6 owner, does the SRT use the same oil filter as the NA?
Old Sep 15, 2019 | 04:14 PM
Default Re: oil filter
Yes, the cheap-assed paper one that collapses under the pressure.
So go with the Mann Fleece filter like we do with NA's.
These are re-boxed Mann Fleece filters you can by locally for around $12-14:
Old Sep 15, 2019 | 05:12 PM
Thank you, I also need to check the power steering fluid. Does the air vent just pull out to gain access to it?
Old Sep 15, 2019 | 05:20 PM
That is a question for someone other than myself.
Old Sep 15, 2019 | 05:33 PM
Clean around cap, unscrew and check level on the dipstick.
Old Sep 15, 2019 | 05:57 PM
That I know but there is a plastic intake tube above it. My question was can that just be pulled out of the air breather or must the air breather be removed? I just don't want to break anything as I figure it out. Thanks for any feedback.
Old Sep 15, 2019 | 07:02 PM
I just skirted around your “air vent” wording as I did not know what you meant by it.
The intake concertinas so you can remove it from both ends.
Old Sep 16, 2019 | 01:29 PM
Thank you for the info #:>)
ws6vert
Jun 13, 2021 10:04 AM
amick6534
May 1, 2018 10:25 PM
maxcichon
37
Sep 4, 2012 08:44 PM
rodimus
Jan 19, 2009 04:15 PM
blacklimitedcoupe
Oct 14, 2007 01:15 AM
