rear subframe bushings worn/missing
Old Nov 20, 2019 | 02:30 PM
racerx999's Avatar
Default rear subframe bushings worn/missing
I recently bought a 2005 SRT-6 and started hearing a clunking noise when driving over train tracks or bumps. I first though the rear hatch lid was loose and making the noise but it wasn't the problem. I took the car to my local shop and they found the rear sub frame has a bushing that rotted and fell apart. They are telling me the entire rear suspension, differential , axles, brakes and wheels will need removed to replace it. Has anyone else had this problem and had it repaired? Feedback please. The car also wanders in the rear while driving on a straight road.
Old Nov 20, 2019 | 03:26 PM
Default Re: rear subframe bushings worn/missing
I replaced the sub-frame bushings on my car will post when i get home tonight
Old Nov 20, 2019 | 07:03 PM
zip439's Avatar
IF and I say IF One of those four "bushings" need replacement, then YES the rear carrier frame must be removed to replace the bushing.
I suggest you look at a parts diagram to see the part in question. I bought a bushing as you call it, just to get the bolt I needed to install a carrier frame (which I bought from a junk yard ) onto my limited 2005 Crossfire. Cost was $28.00 Click here: Mount kit
If the carrier frame (sub frame) needs to be removed you should heat the bolt as there is blue Locktite on the threads.
YOU should be able to see what they are talking about by simple going to their shop and looking at the car up on a lift.
The removal of the sub-frame ( carrier frame) is actually not too difficult. If two techs work together they should be able to drop the frame, replace a "bushing" and re-install easily in 6 to 8 hours.
Old Nov 20, 2019 | 08:50 PM
1 remove your wheels,,,,remove brake lines,,,remove EM brake cable,, remove drive shaft , with fork lift under the sub fram remove the SF bolts,, u need tool to remove and reinstall bushings, I made mine out of pipe and plate and thd rod.,BUSHINGS GO IN ONE WAY . u will see what i mean.the little indent ,, some where i posted a thd on removal and ,,install bushings,,and reinstall ,,can't find it not sure this is all but can't think of any thing else.
Old Nov 20, 2019 | 08:54 PM
I did remove my axles and rear. because
we were changing the rear also,,, there are some susension arms that are bolted to the car you can disconect one end of them
Old Nov 21, 2019 | 09:55 AM
racerx999's Avatar
Thank you all for the replies. My shop is going to replace the two front suspension carriage (as I know now) mounts. The rear two appear to be good. The two mounts were available from our local Chrysler/ dodge dealer for $178.00 each. The shop said they would charge me 5 hours labor. So it is going to be an expensive fix (to me) The shop is replacing the fuel pump and filter and all the fuel lines in the fuel pump/filter area. They where all rotted. The car was a Wisconsin car so it must have spent a lot of time driving in the winter months with the road salt coating everything. The car is now going to be garaged car driven on nice days. I owned a regular Crossfire (2007) for 5 years and loved the car and always wanted a SRT-6. I am so for in love with the power of my SRT-6, it is the what all Crossfires should have been in my book. Thanks again for the info.
Old Nov 21, 2019 | 10:25 AM
zip439's Avatar
racerx, $178 x 2= $356 OR $28 x 2= $56 You could have saved $300 by simple purchasing the parts yourself. DON'T buy your parts from a Chrysler dealer, even a Mercedes dealer is less expensive than Chrysler if you go to an online Mercedes dealer site. Your car is an 2003 Mercedes SLK32 for most everything mechanical and even electric, just the skin is different.
5 hours is very reasonable for labor; Hope it works out well for you.
Old Nov 21, 2019 | 02:29 PM
racerx999's Avatar
That sucks on the price of the parts. I think my shop wanted to go through the Chrysler dealer to have confidence the parts are correct. I will see if I can find the mounts online. Would you have a part number for them by chance?
Old Nov 21, 2019 | 03:32 PM
or on ebay the two on the front of the subframe are different than the rears are if i remember the rears are larger in dia.
just look up slk 32 on e bay
SPONSORED
For 2002-2004 Mercedes SLK32 AMG Subframe Bushing 53618DQ 2003 (Fits: SLK32 AMG)
MEYLEHD Rear Subframe front position Mount Mounting Bushing Kit Set for Mercedes (Fits: SLK32 AMG)
Old Nov 21, 2019 | 05:12 PM
cowancom3's Avatar
Here is a link to all the bushings you will ever need.
https://www.autohausaz.com/catalog/k...ame%20bushings
Joe_Lukeman
Aug 9, 2019 09:53 PM
Motorman
U.K.
May 21, 2019 09:57 AM
ardenian
Feb 25, 2016 10:02 AM
Just1n
Aug 8, 2015 11:45 PM
amx1397
Jun 5, 2015 11:32 AM
