SRT6 Nitrous revisited looking for experienced opinions
Old Mar 27, 2022 | 11:21 AM
stryfox's Avatar
Default Re: SRT6 Nitrous revisited looking for experienced opinions
Originally Posted by Da55id
Nice progress!! How are you going to put all that torque to the ground once you've implemented the nitrous? You can see from my sig that I've got LSD and awesome tires, and without nitrous, it still spins the tires like Vegas roulette LOL!
going to run some Mickey Thomsons at the track. At least that is the plan. That and the progressive nitrous controller and some good conditions and luck and it will stick. Not planning on spraying in first at all then progressive after that ramping up and not spraying during shifts.
Old Mar 27, 2022 | 11:25 AM
stryfox's Avatar
[QUOTE=GraphiteGhost;966824]
Originally Posted by stryfox
/QUOTE]
Just a quick question? Is that shock having something rubbing along the outside of it (wheel side)? Am curious...
yes. I have some rubbing issues but only under extreme conditions. The rears rub the well too when I hit a big swell in the road.
suprisingly I have 285 Michelins on the back and they rub more than the 295 Toyos I had on it last set.
The shock rub as best I can tell is only at full lock in reverse.
Old Mar 28, 2022 | 11:40 AM
latemodel21's Avatar
[QUOTE=stryfox;966828]
Michelins are known for running about 10mm wider than other brands of the same size. I run various versions of supersports and this has been my experience.
Chris
Old Mar 28, 2022 | 04:58 PM
[QUOTE=latemodel21;966879]
Chris
I don't have a tire rubbing, your editing is a little off... stryfox has the rubbing issue.
Old Mar 28, 2022 | 05:07 PM
Smile Re: SRT6 Nitrous revisited looking for experienced opinions
[QUOTE=GraphiteGhost;966887]
I could be confused, but I thought I was replying to post 22 as quote .... hmm perhaps there is an issue with post 22?
P.s. Glad you don't have a tire rubbing issue !
Old Mar 28, 2022 | 05:10 PM
[QUOTE=latemodel21;966889]
Me too! LOL...
Old Mar 28, 2022 | 08:30 PM
stryfox's Avatar
To clarify if you look at the top right of the picture with the front rotor you can see where the tire rubs in reverse with wheel at full lock.
the rub in the shock is from the spindle. I can’t be the only one who drives hard enough for that to contact.
Old Apr 3, 2022 | 05:24 PM
stryfox's Avatar
Next step. Still waiting on Holley NOS parts. I can only assume they are in the middle of the ocean somewhere. Lol
as stated above I installed an sl55 fuel pump.
the thought of running lean is still nagging me. I went ahead and ordered from Needswings a fuel pressure regulator kit and some 550 injectors.
I figured this way I will have more options when the setup is done and I put it on the dyno.
I may not need it but this way there is more head room to tune with.
Old Apr 4, 2022 | 09:29 PM
stryfox's Avatar
Ok if anyone wants to chime in.
considering Needswings tweeked manifolds with crossovers or his big manifolds with crossover.
I did a bunch of searching and read everything I could find. Since I’m going with a wet nos kit would theses manifolds be beneficial to reduce et times?
I understand they will lover boost pressure but not sure how that works with nitrous filling the cylinders. Would extra volume be advantageous and see a noticeable gain in this situation?
thanks for any input.
Old Apr 5, 2022 | 09:30 AM
nemiro's Avatar
Any time you can improve flow, it helps. I am having NW build a similar set for my V8 car, but TBH, I have trouble seeing how they help so drastically. People who have them swear that they do magic. I can't see a downside, apart from cost. I do know that similar strategies help on other engines/platforms.
Old Apr 9, 2022 | 09:46 PM
stryfox's Avatar
Parts trickling in. Solenoids mounted.
Old Apr 17, 2022 | 09:54 AM
stryfox's Avatar
Wot switch installed on pedal and wired up.
next is to install the colder plugs I got.
ngk bkr7e-11. Copper v-power. I am going to ap them at .30
Old Apr 17, 2022 | 09:56 AM
stryfox's Avatar
And here it is back in the car.
Old Apr 21, 2022 | 02:51 PM
stryfox's Avatar
After a lot of reading. It amazes me how much information is here if you take the time to look for it.
I have a set of tweaked manifolds with crossovers in the works from Needswings.
when they come I’ll install them and the 550 injectors when my eurocharged dyno date is scheduled.
Old Apr 21, 2022 | 10:06 PM
Da55id's Avatar
are you sure you'll need the 550 injectors? I'm running the stock injectors, but am using the sl55 fuel pump. No problems, easy peasy.
Old Apr 23, 2022 | 12:22 PM
stryfox's Avatar
I honestly don’t know for sure. With the cost of a remote dyno tune I figure it’s better to have them for more fuel if needed. They were not expensive in the big picture. Plus they are new compared to my almost 20 year old ones in the car.
Old May 1, 2022 | 10:35 AM
stryfox's Avatar
Slight change in direction. Going to use v-tech for a tune to get it close then run it on the dyno and have it dialed in with them. Just waiting on some parts from rob to finishing the mechanical end.
Old May 2, 2022 | 06:15 PM
  #38 (permalink)
stryfox's Avatar
Got side tracked waiting for parts. Center console silver parts going viper red.
Old May 4, 2022 | 06:35 PM
  #39 (permalink)
stryfox's Avatar
Reassembled. Ordered the storage bin to replace the cup holder I never used.
Old May 4, 2022 | 10:58 PM
  #40 (permalink)
stryfox's Avatar
Purge test.
