toxic bird in the neighborhood
Old Jul 10, 2011 | 06:29 PM
roctech's Avatar
Default toxic bird in the neighborhood
I don't have the luxury of a garage so my car is exposed to the elements, no big deal since i wash and wax it so often. I have been sick for a week and a bird plopped a quarter size bomb on my hood. It was probably there for a couple of days before I noticed it, long story short it is etched into the paint and will need to be professionally repaired. I rubbed it , polished it black wax, it disappears and then shows the following day. Does anybody in my situation use a car cover on a regular basis. I have a real good felt lined one for the winter but was thinking of getting something for the summer to prevent this from happening again. I have been told that the cover would do more damage (paint rubbing )then it would prevent. Is there a safe, lightweight easy on/off cover for a roaster to use in the summer?
Old Jul 11, 2011 | 12:33 PM
6000rpm's Avatar
Default Re: toxic bird in the neighborhood
I have bought two car covers from Car Cover World. They were for my MR2. I bought the custom fitting kind, instead of the one that fits any car. They are not waterproof, but they let the car breathe. Great defense against birds. There are different kinds; indoors, outdoors with lots of sun, long term storage, daily use, etc.
My MR2 is white, so I have not seen any scratches, but I think a car cover is the way to go. Make sure it is tied down and secure when the weather gets windy! I use it every day. Very easy to remove and put on the car.
Car Covers | Covercraft & Coverking Car Cover, SUV & Truck Covers
Good luck getting that bird bomb fixed.
Old Jul 11, 2011 | 04:05 PM
Mike-in-Orange's Avatar
What did you rub it and polish it with? If just a wax like the Turtle Wax Black Box stuff it's not going to come out at all. You should be able to remove it by hand using something like Meguiar's Ultimate Compound and a foam wax applicator pad.
Old Jul 11, 2011 | 04:20 PM
roctech's Avatar
First tried rubbing compound and then waxed over it, looked good, next day it reappeared. Then i claybared area used meguiars swirl x and meguiars polish followed by insulator wax, looked great, next day it popped again. Now i get desperate and use polishing pad from headlight restorer with a little water and some polish at low rpms. Looked like i left a small faint mark in the sunlight but after applying cleaner wax this time and some insulator wax it looked great again but popped through again. I tried turtle black wax as last resort. I think it needs to be wet sanded and polished with buffer, and I am not that talented. right now its very faint, just want a summer cover so this doesn.t happen again. This bird must have ate acid
Old Jul 12, 2011 | 12:38 PM
Airscape's Avatar
Was it purple by chance? some deamon dropped a purple duke on my hood and ultimate compound as well as the one from the new microfiber kit won't do anything to it using the porter cable. Gotta look for it in the right light/angle but the mark is still there.
Old Jul 12, 2011 | 02:05 PM
atlsrt44's Avatar
yeah bird crap is very acidic. I had a white infiniti and came home one spring and the car was covered from bumper to bumper with birdcrap and purple berries. Apparently they would eat these berries and then not be able to digest them...
Old Jul 12, 2011 | 04:27 PM
dtinker's Avatar
Rub the area down with alcohol first, make a paste of baking soda. Put the paste on the spot, donot rub, just let it sit on the spot at least 45min. Clean the area again with alcohol, being careful to not rub the dried paste. If you rub it it will scratch. Now use some 1500-3000 grit compound. Put a good wax on the whole area being very careful to get all the compound, paste, etc. off Polish it up that should neutralize the acid in the bird droppings. Find the bird and make sure they don't come back!
Let me know if that cures or helps the problem.
Old Jul 12, 2011 | 09:31 PM
Alicia's Avatar
dtinker- that is some interesting procedure. How did you come up with that process? I hate that bird stuff - makes looking for shade in a parking lot a real gamble. Alicia
Old Jul 13, 2011 | 06:57 AM
dtinker's Avatar
I used to own a franchise called " TIDY CAR" that did paint sealants, detailing, etc. Bird droppings have a lot of acid in it. The baking soda neutralizes the acid. The alcohol just cleans the wax away so the baking soda can contact the acid. You need to leave it in contact for a while so it has time to go into the paint. Hope it will do the trick.
Old Jul 16, 2011 | 01:05 PM
dtinker's Avatar
roctech;
Did you have a chance to try my fix for the bird droppings on your car? The faster you neutralize the acid the better. It will just keep burning the paint if you don't get it all off. Let me know if it solves the problem.
Old Jul 16, 2011 | 02:59 PM
roctech's Avatar
Originally Posted by dtinker
roctech;
Thank you for the tip, I just tried it in the hot sun, I used a couple of alcohol rubs I had in medical kit and applied wet paste with a wet towel over it. Thirty minutes later i cleaned up paste carefully with water and micro towel. The hood was very hot , black car in the sun, however I applied polish to area rubbing it aggressively and then waxed. It took me the next ten minutes to find where the spot was, it is faded 90%. Unless you knew it was there and looking you would never spot it. The next time I detail the car I will try rubbing the remainder out I would have to say that is a great Tip. Thank You again, and anybody with bird stains give it a try, very easy fix.
Old Jul 16, 2011 | 04:00 PM
dtinker's Avatar
Glad it worked, get it in shade and do it again and let the paste soak into the paint. The baking soda is a miricle product. Soak it for about an hour if you can, spread it out to a larger area that the spot. This will allow it to get the acid out. Great stuff.
Old Jul 16, 2011 | 08:46 PM
magneticred's Avatar
An alternative solution:
‪Ford Sport Ka - Evil‬‏ - YouTube
Old Jul 18, 2011 | 06:49 PM
maclovinX's Avatar
Tinker,
Thanks! I've got a Ridgeline with a few stains i would like to lose!
I'll give it a try.
Thanks!
Old Jul 18, 2011 | 07:01 PM
dtinker's Avatar
Just make sure it's just plain Baking Soda.
Old Aug 11, 2012 | 05:04 PM
coolx's Avatar
I typed "bird poop" in the search box and got the answer to my question - thanks dtinker and all you guys who post helpful hints!
rfourt
Aug 12, 2020 07:27 PM
Ralph289
Jul 26, 2015 12:52 PM
Sidez
Detail Shop
Feb 16, 2007 11:48 AM
bollox
Sep 18, 2006 07:55 PM
Creator
Aug 3, 2004 09:44 PM
