turbo or supercharger???
Old May 27, 2009 | 07:43 PM
6speed05fire's Avatar
Default turbo or supercharger???
ok I have a turbo that im sick of looking at soo should i slap it on the old fire or should i buy a supercharger that i found and a junk yard it has 3000 miles on it for 800 bucks. the car was rear ended and smashed. i have had turboed cars before. I know theres alot more fine tuning to a turbo than there is a supercharger. I have a limited with a couple mods exsaust cold air better plugs and wires, just little stuff done.
Old May 27, 2009 | 09:00 PM
mrphotoman's Avatar
Default Re: turbo or supercharger???
i think a junkyard supercharger sounds mad tyte yo!
DO IT DUDE DO ITTTTTTTTTTTT!!!!!
Old May 27, 2009 | 09:01 PM
mrphotoman's Avatar
p.s.: DO IT NOWWWWWWWWWWWWWWW!
Old May 27, 2009 | 09:07 PM
mrphotoman's Avatar
Just checking in, did you do it yet?
Let me know, thanks
Old May 27, 2009 | 09:08 PM
Moparrbust's Avatar
Let me know, thanks
He's probably out at the salvage yard unbolting the damn thing...............give the man some time. lol
Old May 27, 2009 | 09:09 PM
mrphotoman's Avatar
I am just really excited, i know he can do it!!!!!
Old May 27, 2009 | 09:27 PM
black05's Avatar
here we go again....
Old May 27, 2009 | 09:28 PM
kolevski's Avatar
Lol someones hypo? before you know it he might come and un bolt your s/c
Old May 27, 2009 | 09:30 PM
kolevski's Avatar
Since this threat ended before it started I want to ask a question lol.
Moparrbust, remember a while ago you made a thread and you were doing something to your transmission? I cant find the thread what did you end up doing?
Old May 28, 2009 | 06:38 AM
apkano's Avatar
Life is random...so am I.
I think you should install both!
Stage them correctly and you can have the supercharger for getting up to speed, and then the turbo for top end without any supercharger robbing power! If you wanted to be really trick you'd put in a switch and clutch so you could disable the supercharger entirely.
Just did a little math, the way I see it this setup will require at LEAST 6 blow-off valves, with one after the muffler being mandatory.
You're right about the tuning, supercharger boost is read entirely different than turbo boost when it's going into the engine. You could get one of those sweet power programming chips off e-bay though.
Old May 28, 2009 | 07:34 AM
daylight4449's Avatar
First reply from a new member.
Is there an "new" after marker supercharger for my 2005 Limited coup?
I would like to increase the performance in a number of way but so far have only found a Magnaflow complete exhaust system.
All suggestions will be appreciated.
Old May 28, 2009 | 11:47 AM
ZAHANMA's Avatar
ok, so you will probably get flamed bad for asking this... so I'll just say this...before you ask the next question that comes to mind...use the search function and see if it has been previously discussed.
with regards to your question there has been some failed attempts at supercharging the N/A motor in the Limited. However, I think the cast engine can not withstand the forces of anything over about 6psi leaving you wanting a heck of a lot more power and nowhere to go.
The computer is a completely separate issue and a big deal.
If you really want a supercharger, then the best solution is buying an SRT.
Originally Posted by [B
6speed05fire[/B]]ok I have a turbo that im sick of looking at soo should i slap it on the old fire ...
turbocharging the crossfire has been tossed around for quite some time now...but all to no success... you can't just slap on a turbo on the crossfires and expect magic...good luck with your endeavours, but i personally don't think it is a smart option.
Old May 28, 2009 | 01:02 PM
Tamadx's Avatar
Originally Posted by ZAHANMA
turbocharging the crossfire has been tossed around for quite some time now...but all to no success... you can't just slap on a turbo on the crossfires and expect magic....
time will tell...
Old May 28, 2009 | 02:41 PM
Tamadx, you have an SRT listed in your signature, is there any reason you are interested in turbo applications???
Not trying to be a ****, just wondering.
Old May 28, 2009 | 05:54 PM
i kno you cant just slap a turbo on. Ive turboed a couple cars i kno how it works. i wouldnt just slap one on any stock motor it needs to be full built im talkin start from block and then up i spent over $2000 in just the head of a s2000 i had it takes alot of time and money i would rather have the charger because of the less power and less fine tunning. Turbos are a pain in the a$$ but once its fully set and tuned its amazing. Im going to the yard this weekend.
Old May 28, 2009 | 06:46 PM
sonoronos's Avatar
My opinion:
You're not going to find a supercharger that makes big power at a junkyard, unless it's coming off a Ford GT. GT4294R or go home
Old May 28, 2009 | 06:48 PM
mrphotoman's Avatar
I logged on when I got home and looked at the index page and I was all like when i seen that you had replied to this thread.
I was thinking he is all done with that super turbo ultra charger setup on his fire!!!!!!!!!
then i was all like when i clicked on the thread and seen that he had not installed it yet.
but, then i was all like again when i seen that he was all on that sh*t this weekend!
Old May 28, 2009 | 07:04 PM
ahhaha damn dude if you have this much energy, i might ask u to come over and help me do it. lol just give u some sugar and 30 mins later bammm the beast is done lol
Old May 28, 2009 | 07:08 PM
i just dont understand why there is a handful of people hating on me for this. its ok though, laugh now cry later.
Old May 28, 2009 | 07:10 PM
mrphotoman's Avatar
just do a search, many people have tried and all have failed.
hopefully you will succeed but it is doubtful. do a search and you will find out why.
