A Serious WTF - Split Weld on Catalytic Converter!
Old Sep 14, 2009 | 08:46 PM
texas t's Avatar
Exclamation Re: A Serious WTF - Split Weld on Catalytic Converter!
What is the build date on the xfires with cat failure, maybe same day or week?
Old Oct 24, 2013 | 11:27 AM
Sennaspirit's Avatar
Default Re: A Serious WTF - Split Weld on Catalytic Converter!
Originally Posted by CALL911
Your converter is covered under warranty for 100,000 mi. Federal law, I think. Don't know if they would have covered it with your exhaust mods, but for anyone else with this problem, take it back to the dealer.
just wondering if this is true? have a cracked front cat so i'm interested in options i have.
Old Oct 24, 2013 | 11:43 AM
I have both front and or rear with less than 30,000 miles on them if someone is interested jim
Old Jan 29, 2014 | 02:07 PM
SRQfun's Avatar
My left front converter is cracking around what should be the weld... Need to get it to a shop that will weld it for me. 3 shops so far want to replace it
Old Jan 29, 2014 | 03:33 PM
I have all 4 off my V6 with 30,000 miles on them would take 100 each or make me an offer, then you can take it back to one of those shops and tell them,Here: replace it. lol. jim
You should replace them in pairs as one old one will flow less than a new one ,,in pairs like mine with 30,000 miles on all 4 .
Old Feb 26, 2014 | 01:25 AM
seannon's Avatar
do you still have the cats? I have my xfire in the shop right now with what may be the same issue... the shop said it was a "Broken left cat", and I would rather put an OEM full set on (and have the welds checked first and fixed if necessary) because as an aircraft mechanic, I know the issues of unbalancing the pressures... if so, email me please at my Id @gmail(dot)com
Old Feb 26, 2014 | 08:02 AM
Yes,, I just looked at then last night. they look New.
Old Jun 23, 2014 | 10:03 PM
Mocephus's Avatar
Wound up with the same problem on my left cat. Looks like a manufacturing defect. Took the pipe off and had the welder at work run a new bead all the way around. Worked like a charm. He said it looked like the alignment of the weld in relation to where the casing and the end cap meet, was off center. The right cat was just fine. Considering I've got 130k on the odo and this is the first thing to go wrong, I'm OK with that
I did check Rockauto.com just in case and they have the left one (20400), complete with the one front and both rear cats for around $280 plus shipping and it's a direct replacement. They also have the right for about $100 less.
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
franklindm
Mar 14, 2020 12:23 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
