Valve cover leak...
Old Mar 29, 2021 | 09:30 PM
  #401 (permalink)
Flintfire's Avatar
Default Re: Valve cover leak...
Great information on the valve cover maintenance. I am in the process of fixing a leak on my valve covers. I have some damage to one of the hoses on the valve cover. Are there any replacement hose sets for the valve covers. the hose seem to be brittle. Anyone know part numbers for the hoses?
Thanks
Old Mar 29, 2021 | 09:53 PM
  #402 (permalink)
These ?
CLICK
Old Mar 29, 2021 | 10:46 PM
  #403 (permalink)
Flintfire's Avatar
Thanks ala_xfire! just what I needed. Hopefully I can return the favor some day. Thanks!
Old Mar 30, 2021 | 01:06 AM
  #404 (permalink)
Where in Alabama are you ?
Old Mar 30, 2021 | 07:23 AM
  #405 (permalink)
These ?
CLICK
Thanks
Just remember to do your part searches referencing the M-B Series SLK320 for model years 2001-2004 like the eBay listing states hose kit is compatible. Here's another site that lists the crankcase breather hoses individually, if you're only interested in replacing what's defective. CLICK But I concur with ala_xfire, if you're going to change one hose, might as well change the whole set.
Old Mar 30, 2021 | 10:11 AM
  #406 (permalink)
NeedsWings's Avatar
we have a set in stock and can ship today for you
NeedsWings Performance Products. Part Load Crankcase Ventilation Hose Assembly m112
Old Mar 30, 2021 | 11:07 AM
  #407 (permalink)
Flintfire's Avatar
Huntsville
Old Mar 30, 2021 | 11:16 AM
  #408 (permalink)
Flintfire's Avatar
Ok, I want to replace all the hose associated with this valve cover maintenance. Thanks for everyone's help. 2004 XF 45k miles, subs refurbished, TPM light wire removed, but have after market unit in operation for TPM, new radio for USB support/phone. loving this car and this forum! Thanks
Old Jul 16, 2021 | 07:34 PM
  #409 (permalink)
KowalaGT's Avatar
Great post! I love this forum, 12 years after OP and still helping an X-fire brother out!
The service manual I downloaded from this forum (again, I love this forum) says use a 1mm bead of sealant. I put some RTV in a 20ml syringe to make a very fine bead. When finished there was no silicone oozing out from the seam; time will tell if this method is successful.
Old Jan 17, 2022 | 11:08 AM
  #410 (permalink)
kowaltoboggan's Avatar
Rob,
Quick question for you on this set of hoses. Does the kit contain all three hoses that attach to the breathers? The right side has one breather hose coming from it. The left valve cover breather has two -- one that is the same diameter as the right side breather; the second comes off the back of the left valve cover breather that is larger than the other two.
Many thanks, John
ps-- What a great resource it is to have NeedsWings supplying these parts. Without you guys, it is much more difficult to get the correct items for our XFs. Happy to support you.
Old Jan 17, 2022 | 12:20 PM
  #411 (permalink)
NeedsWings's Avatar
that assembly is the smaller diameter hoses / fittings from both valve covers to the throttle body. the larger diameter hose from the driver side valve cover to the MAF housing woudl be this one
https://www.needswings.com/full-load...tion-hose-m112
Old Apr 5, 2022 | 03:21 PM
  #412 (permalink)
DKAwildcat's Avatar
looking good
1. you can remove the oil fill cap extension neck, use a flat screw driver and pry up on it from the back side and twist off counter clockwise. you can then screw the oil cap directly onto the valve cover and eliminate a potential leak point.
2. I would like to see the hose clamp on the hose connecting the drivers valve cover to the CAI's MAF housing (I sent 2 of them with the kit).
3. you can remove the 4 rubber mushroom grommets on the valve covers as you no longer need them with the CAI
4. your missing the passenger side wiper arm nut cap
5. a little bit of brake cleaner and a plastic brush would go a long way on the top of that intake manifold to bring back its glory.
It looks like I have an oil leak at the base of the oil fill cap extension neck (No. 1 above). Is there a gasket or o-ring there that needs to be replaced? It sounds like it’s an easy fix without having to remove the valve cover.
Old Apr 5, 2022 | 03:29 PM
  #413 (permalink)
NeedsWings's Avatar
https://www.needswings.com/oil-cap-gasket
Old Jul 5, 2022 | 12:27 PM
  #414 (permalink)
Sussudio's Avatar
Rob I’m in the process of replacing my valve covers and I’ll be using your upgraded steel bolt kit I bought a few months back. Do you happen to know the size of the Allen head so I can pick up a proper bit for a torque wrench? Thanks in advance
Old Jul 5, 2022 | 01:26 PM
  #415 (permalink)
dcskmail's Avatar
I don't think it's a ventilation problem, just the RTV sealant getting old and breaking down
Old Jul 7, 2022 | 01:14 PM
  #416 (permalink)
NeedsWings's Avatar
5mm and 4mm
Old Jun 20, 2024 | 05:06 PM
  #417 (permalink)
LVXF's Avatar
I've got some of those 16mm aluminum screws. $7 for 5 or pick up a set in Las Vegas for $5.
Old Jun 21, 2024 | 07:51 AM
  #418 (permalink)
DTMenace's Avatar
LVXF
You responded to a 2-year-old posting, doubt if they are still waiting on a response.
Look at the dates before posting....
Dennis
DTMenace
Old Dec 21, 2025 | 08:05 AM
  #419 (permalink)
mikespine's Avatar
Just for ***** and giggles: December 2025 price is $42.54.
Here is a complete set for 25 bucks :
https://www.fcpeuro.com/products/mer...30-m1123pcvkt1
batmanmiami1
Sep 23, 2020 08:34 AM
BisB
24
Mar 7, 2018 01:41 PM
roychez
Jul 27, 2014 08:11 PM
psuperti
Mar 31, 2012 12:01 PM
oojacoboo
Dec 14, 2010 02:24 PM
