Another "lifter tick" thread, with a twist
Old Apr 7, 2010 | 02:32 AM
805_Fire's Avatar
Default Re: Another "lifter tick" thread, with a twist
Originally Posted by mjgroves
For those of you who are curious... I had a specialist listen to my car and he said there was absolutely nothing wrong with it. He told me that the ticking noise I am hearing is the fuel injectors, definitely not caused by a collapsed lifter.
So I guess I was just being too picky with the sound. I guess we just have loud injectors.
Thanks, I noticed my car makes this noise you can hear it more when in a fast food drive thru lane, good info.
Old Apr 7, 2010 | 03:57 AM
Infinite's Avatar
Originally Posted by Infinite
mercedes motors have loud injectors, just fyi.
tons of people confuse lifter tick for injector tick
Ding Ding
I win
Old May 18, 2010 | 01:23 AM
818.crossfire's Avatar
Wow....that sounds terrible. That doesnt sound normal to me at all!
Old Jul 18, 2010 | 03:33 AM
SillyMan's Avatar
I just bought an 07 Limited roadster with 30,000 miles and have noticed this as well. Do some of the cars make this noise and others do not? I don't remember hearing it on others I was test driving.
Old Jul 18, 2010 | 02:59 PM
Paul Bosslet's Avatar
Well, (just my 2cents worth), my '05 n/a with 75k idles smoothly and is very quiet. It ticks a little on cold startup but then the noise is gone in a couple of seconds. When at a stoplight, I have to look at the tach to know the engine is running!
Old Jul 18, 2010 | 03:29 PM
Ok, here are the two files I attached. They are both about 15 seconds in length, one is with the engine cold and one is with the engine warm. Aptly named warm.txt, and cold.txt.
Ok, now I know I am NOT the most obsessive person on here.
There is no way THAT is a LIFTER. I have heard bad lifters before and that ain't it. I know, the mystery is over and I'v come to the party after all the pretty girls are taken - but just had to chime in. You make me smile - cause even I wouldn't have worried about THAT noise!
INFINTE: You are only 23 - did you really EXPECT anyone to listen to you?
Old Jul 18, 2010 | 03:41 PM
Infinite's Avatar
yea well, **** happens I guess.
Part of the reason the injectors are so noisy is because of how high the base fuel pressure is. The injectors are open a very short duration at idle, and the fuel pressure is so high it basically slams the injector shut when current is removed from the injector. The pintle slamming against the seat is basically what you're hearing.
Old Jul 19, 2010 | 10:49 PM
BlueStorm's Avatar
that theory makes no sense, when you start up the car, it maks a loud ticking sound for about 2-3 seconds, and then it goes away after that. so are you saying the fuel pressure changes within a few seconds of start up?
Old Nov 6, 2010 | 09:12 PM
scotty883's Avatar
i own an 06 chrysler 300 and i have the same noise. i was told by the dealer it was loud injecters but some people i know who are very well educated and who have been working on car for as long as i have been alive have said it is injecters. its been over a month and it has gotten worst. it is louder now. it sucks cuz i spent alot of money on it and only after several weeks did it start to make this noise. i bought it used with 81k. ive seen and heard the saying..."the chrysler tick" for this case. it seems chrysler manufacters their engines and have not taken heed to this issue.
Old Nov 6, 2010 | 11:04 PM
Joliet John's Avatar
I'm surprised no one has suggested an exhaust leak.
Old Nov 6, 2010 | 11:14 PM
Mine does make a sound for up to 5 seconds on cold startup, I am convinced it's the lifters. I hear it in many of the cars at the Dragon.
But the remaining tick sound is said to be the injectors. This is a sound heard on a LOT of engines these days, I have heard it on Ford and Dodge engines in the police cars we work on at the shop.
I think INFINITE is probably right about what he is saying about the cause of the noise in the injectors AND about the fuel pressure. NO, the pressure probably does NOT drop muich on startup, but the lifters do quiet down with a little oil flow!
Valk
Jul 12, 2021 09:49 PM
MiamiTVR
Jan 30, 2016 02:15 PM
Sep 26, 2015 10:21 PM
grip grip
Other Cars Etc
Sep 26, 2015 09:52 PM
Sep 25, 2015 07:46 AM
