Primary Cat Removal
Old Apr 9, 2010 | 10:25 PM
kolevski's Avatar
Default Primary Cat Removal
If the primary cats are removed will there be any problems? e.g. car doesnt run right (rich/lean) engine lights?
I was told by my exhaust person that if I were to take out any of the cats it would be better to do the primaries because throttle response would be significantly improved.
Old Apr 9, 2010 | 11:12 PM
Voyager's Avatar
Default Re: Primary Cat Removal
I am not a hundred percent sure but pretty sure, that if you remove the first two, it would throw a code because that is where the o2 sensors read from. the second pair is ok to remove though
Old Apr 9, 2010 | 11:59 PM
kolevski's Avatar
Thanks Voyager, I could take out the secondaries and put an X Pipe in there place, but if I knew for sure taking out the primaries wouldn't throw a code it would be much more beneficial to take them out.
Old Apr 10, 2010 | 01:37 AM
Voyager's Avatar
np, and for a little info, I have removed my second cats and the car runs wonderful. but I don't think removing cats does anything to the hp or tq. but I am 99% sure the primaries will throw a code, POSSIBLY pull timing. lol don't quote me on that though
Old Apr 10, 2010 | 01:40 AM
Voyager's Avatar
I did a little bit of snooping and found this link on the forum. HOPE IT HELPS! good luck with your car. https://www.crossfireforum.org/forum...at-delete.html
Old Apr 10, 2010 | 02:20 AM
kolevski's Avatar
Thanks man, that was a good read and it just confirmed that its more trouble then its worth!
I'll just go with taking out the 2 rear cats, did you do an X pipe or just straight through pipes? I've deleted my resenator I hope it doesnt start to drone.
Old Apr 11, 2010 | 11:57 PM
Violenteer's Avatar
kolveski,
i have two high flow cats as primary and no secondary cats.
i also have o2 spacers.
does not seem to be a problem.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
55chevy
Sep 13, 2015 07:38 PM
