185mm crank pulley
Old Mar 13, 2011 | 08:26 PM
dinasrt's Avatar
Default Re: 185mm crank pulley
Originally Posted by svtcobra
but my machanic was telling me the the keyway broke off in the 185mm keyway slot so they ordered another keyway and they are goin to remove the crank seal to get the rest of the old keyway out and put the new one in and im ready to rock. with that being said he was thinking that the old keyway was already weakinig and with the extra spin on the crank with the new pulley it broke;(
What happened (symptoms) that your mechanic needed to look and see if the key in the keyway was broke?
Old Mar 13, 2011 | 08:38 PM
32krazy!'s Avatar
yea im hoping i lucked out on it .......... do you think it was because of improper instillation when i bought the pulley jerry stated that if i dnt torque the crank bolt to like 350 i believe that it would mess up the crank. when my mechanic put the pulley on he used a impact so idk
the proper way to install the crank pulley requires a large torque wrench and a dial gage. you torque the NEW bolt to a specified torque then 90* more. the flywheel must be locked to prevent the crank from moving . if your mechanic isnt familiar with the proper procedure he shouldnt be messing with your car. if he is using an impact wrench you are inviting disaster. think what will happen when the pulley shears off the end of the crank at 100mph+ at the track. not a pretty sight
Old Mar 15, 2011 | 07:57 PM
SRT6_Roadster's Avatar
Originally Posted by 32krazy!
as for handbuilt engines the machines may torque the bolts but the assembly is done by a single builder and everything is documented unlike an assembly line engine were they are handled by dozens of people . magical ? no. able to be replicated? again no
What do you mean not able to be replicated again? If someone blows an engine they have 2 choices 1) replace it with another hand assembled engine or 2) have it rebuilt which is most likely completed by a single individual.
Old Mar 15, 2011 | 09:26 PM
Moparrbust's Avatar
2) You forgot to mention that engines are usually rebuilt by a guy that could care less about putting the proper high quality replacement parts, following proper procedures(if they even know them) and take no pride in what they build.
I have several friends(and myself included) that have had various make/model engines "rebuilt" by different local machine and performance shops and all have had cheap new parts(ie cast orhyper u pistons instead of forged) installed when paying for good stuff, old parts(nuts bolts gaskets) re-used when they are clearly one time use and in my case an engine that was bored .040 over and not hot tanked(but paid for it) and had metal shavings clog up oil passages which dropped pressure and blew motor after 50 miles. I found one guy that was building race engines only that re-built my "re-build" engine and he said it looked like it had 100,000 miles and was the worst rebuild he had ever seen. He gave me a folder with all the work he did and all of the specs of EVERYTHING down to the thousandth of an inch so I could give the paperwork to a (reputable)builder and they could replicate it without needing my engine. Shortly after building my engine his place was bought out and shut down.
Old Mar 15, 2011 | 11:10 PM
loungn14's Avatar
sorry to see that happened. 100% of the time the keyway goes, its bad install. If he put it on with a impact gun without proper torque, that would definately cause the bolt to back out and sheer the keyway. I have seen 7-9 of these before, with the same results. I have yet to see a "weak" keyway before. Like posted above, follow the correct install procedure and you won't have any problems.
Torque properly and add that extra 90 degrees to lock it down. They are stretch bolts, one time use only!
hopefully you can just replace the keyway and the crack is ok!
wishing you the best, if you need anything let me know!
Old Mar 16, 2011 | 05:09 PM
I have to give you that point. Reminds me of a friend that had his Supra motor rebuilt only to have issues and had to have it rebuilt a second time.
That being said I am fortunate enough to know a couple of shops that care about the work they do, have the knowledge, and will put in the time, effort, and parts to do it right.
Still even if you know a shop that will do it right no one wants to spend the money to rebuild an engine due to an issue. Not a fun way to spend money.
Old Mar 16, 2011 | 09:19 PM
svtcobra's Avatar
Banned
Overall even tho i experienced my 185mm crank pulley being installed i dnt regret it and i would do it again the results are amazingggggggggggggggg. after i get my keyway fixed i will be getting the Eurocharged 185mm crank pulley installed the again but the proper way.
Old Mar 16, 2011 | 10:16 PM
ZAHANMA's Avatar
Always glad to hear that. I love having my 185. Have had it for over two years.
Old Mar 17, 2011 | 01:05 AM
dinasrt's Avatar
I'm trying to learn here. Could you elaborate a little more about what is being done to "fix the keyway".
Old Mar 18, 2011 | 12:14 PM
svtcobra's Avatar
Banned
From what the dealership is telling me is that the keyway is a small half moon shape key that slides into the front of the crank in which the top part goes into the pulley. And what happened was since my machanic didnt torque the pulley properly it sheered of the top of the moon shaped keyway. so now the dealer has to go in and get the rest of the keyway out and put the new one in
Old Mar 18, 2011 | 12:27 PM
loungn14's Avatar
correct, which is a hell of a lot of work and hours to do. Hopefully nothing else was damaged like the crank.
Old Mar 18, 2011 | 12:54 PM
MikeR's Avatar
guys, just for the sake of clarity..... the keyway is the groove in the the shaft that the KEY(half moon piece) fits in.... there is a notch in the crank shaft that the key fits into and your crank pulley has a groove cut in it that the key slides into...this is what keeps the pulley from spinning on the crank shaft...the crank bolt holds the pulley on the end of the crank shaft....
If the key has sheared then you may get by with cleaning up the surfaces and replacing the key....
If the keyway was damaged they would have to recut it or replace the crankshaft and/or pulley....
Old Mar 18, 2011 | 01:49 PM
tunaglove's Avatar
But you also need some force from the bolt to push on the hub of the pulley. The key could never hold that much force by itself, if the crankshaft is slightly longer than the pulley hub (because the tolerances are not checked and matched at assy.) no matter how tight you go on the crank bolt the key will break.
I would install the pulley but only tourqe the bolt a little, remove the bolt and see if you need to shim behind the pulley hub.
My $.02.
Old Mar 18, 2011 | 07:54 PM
MikeR's Avatar
Agreed... that is why you tighten that bolt like a sum beetch...
rmcdaniel12
Nov 4, 2015 04:08 PM
4drturbo
Oct 2, 2015 12:58 PM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 02:16 AM
