Engine, Exhaust, Transmission and DifferentialPost questions here that have to do with the engine, cooling system, air intake, exhaust, Transmission and Differential
I have watched this from afar for quite some time.
Congratulations.
That is amazing. I want picks of those headers and exhaust path. I'm sure I speak for many.
Be careful with those headlights. The light bulb change looks like a PITA.
Any more on this kit im really thinking about putting 5-7 lbs of boost on the crossfire and am wondering if i have to go 100% custom or if i can cheat with this kit.
- thanks
Several ppl would want to add a turbo, or twin t3, but from what I gather the problem is if you try to add boost the ecu will not read it.
don't know what they did to finally make it work, and I don't know how much boost he is getting, wish I did, and how it is working.
might have to put resistors in the pressure sensors to trick the computer then tin to make it run rich, which will even out.
depending on which resistor to be used will adjust sensors voltage and they will read less than what actually is.
so ecu would just think it is tuned to run rich.
every atmosphere of pressure doubles power, so at 14.7 psi you will double you engine hp, but also have to account for the power used by supercharger / turbo.
Kit isn't going to happen. I've got the one and only. I see 4, 5 pounds of boost. Feel it too! Cold blooded in cold weather on starts. Have to warm it up a bit before driving off. Exhaust is a bit loud (for me). Headliner is out. I don't drive it. Finding my Crossfires too hard to get in and out of. :-(
Well... I've spent 30mins. this morning , blowing up an roaming around that engine compartment. I'm gonna spare you the 15 dozen questions , that come to mind an say , "I hope its everything you dreamed it could be!" It truly is , one of a kind.. I like it!..
