Oil Catch Can and cleaner tips...
I've had my oil catch can (home-built) installed for a few months now and one of the side benefits I've noticed is that no matter what gas I buy (93 only) wherever I buy it, my exhaust tips remain very clean. And I mean NO black sooty crud that y'all know about.
Any one else notice this?
It means to me, in my covoluted way of thinking, that not burning that oily crud is actually quite noticeable. At the rear end of the car...
Yes? No?
I should mention that my design is a very efficient removal tool. Not just an eBay special, even though I used a $20 can and fittings from there to start with!
Yes? No?
Yes? No?
Yes? No?
God willing, I can have mine on and get some miles on it before the winter hits, but the new daily is taking a lot of my time.
Will try to let you know as soon as its done...
Yes? No?
Yes? No?
Neighbor is jacking with you and cleaning them when he leaves for work in the mornings!
My neighbors replace their cars when they get dirty. A bucket, let alone 2, are things that they just don't/won't know how to use!
Did you notice any change/improvement at all?
And, trust me guys, she gets plenty of WOT. Only a paltry N/A, but still.....
THe fuel curve is altered by the relative boost and so its much more of an issue with the ecu trying to match the F/A values. It errs on the rich side to be safe, Iam at 14.7 with smooth granny driving but all over the map with spirited driving.
Woody
Woody
Noticed a big stream of oil under the car after sitting a couple days after getting back from the 2000 mile return Dragon trip. Traced it to the bottom drain **** on the catch can. It was still tight but leaked out till it vwas empty. Had to put teflon tape on the theads to stop it. Anyone else have this issue?
The instructions say that Teflon tape is applied to the threads when installing the catch can.
I assume that those are the threads you mean. If it's the drain itself it must be faulty.
I actually read this originally but doubted the need for tape because of the number of threads. Didn't really consider the pressurization could force oil past the threads.
PS I was quite happy to find the leak at the catch can as the oil was dripping from the black cast steering box so I was fearing the worst.
It just leaks because it is a pipe thread and they do not seal as there are gaps at the bottom of the threads. It's a good job you do not do gas pipe installations.
I have never checked my can yet, I do not expect too much.
It'll soon be time to get the covers out. They put brine down on some roads last week.
Gonna drive my car all winter.......just kidding. A couple weeks and that will be it for me.
I was surprised by how much had leaked out since my trip. Drained the catch can before I went and there was enough to run down the fender onto the floor and roll past the front bumper. Thats got to be four or five ounces?
Brrrrrrrrr
Okay problem solved. The teflon tape is only required where the fitting threads into the catch can. There is supposed to be a little black O-ring that sits in the threaded cap. Mine must have stuck to the bottom of the catch can spigot instead of staying in the cap and then fallen into my drain/coffee cup. Just found the cup still upside down in my oil used oil collector/ pan and low and behold there is my o-ring stuck to the bottom of the coffee cup.
Thanks BEANER !
Thanks BEANER !
