Catch Can
Thanks for chiming in. Any idea of why mine is the tan gook and most others are getting a dark fluid?
Could it be from only driving occasionally and usually short trips leading to more condensation?
BTW it was separated in the can. When I emptied it the gook was plugging up the drain. I had to stick a screw driver in and then the water came out.
I double checked it is installed correctly. The hoses are clear with only a slight residue. I cleaned out the can with gas and a lot more of the tan residue came out but was much darker. From the can walls no doubt.
