Ignition key gets stuck / throttle cable module
Old Aug 7, 2021 | 10:11 AM
Default Re: Ignition key gets stuck / throttle cable module
Read the prior post.
Old Aug 7, 2021 | 12:03 PM
zip439's Avatar
Originally Posted by Ironworker 6
Hey all, having the same issue with the key stuck in the ignition. Can start the car and drive it but can’t get the key out. Dealer recommends a new shifter module which is not available anywhere. Does anyone know where to get a shifter module or will removing the black park lock cable fix the problem or can the park lock cable be adjusted on the shifter end?
First things first; GET YOUR CAR OUT OF THE DEALERSHIP!!!!!!!!! You will pay a bundle and probably never get your car fixed. Dealers no long have the scan tool or expertise to repair your car. You can do the repair yourself or take it to a indepeneant European automobile repair shop. GET YOUR CAR OUT OF THE DEALERSHIP!!!!
Next click this link and read it.: ignition Key fix
Old Aug 7, 2021 | 12:37 PM
Just read the PDF file attached to post #1, everything else will just confuse you.
jmccaskill
Apr 22, 2015 08:43 PM
eatmycrackers
15
Feb 3, 2015 11:04 AM
pjm30144
Nov 11, 2013 06:24 PM
jekyll919
Mar 5, 2012 05:38 AM
rigamo
Oct 30, 2011 11:21 AM
