Microlon engine treatment
Re: Microlon engine treatment
Today talking to my aircraft mechanic he recommended I put Microlon in my aircraft engine, he is a very experienced mechanic, and has done his own testing in aircraft. By just treating one engine in light twin engine aircraft and using the untreated engine as a baseline he feels this treatment really does work. He states all the owners had the other engine treated after seeing the results. Most aircraft have oil temp, oil pressure, CHTs, EGTs and fuel flow gauges, so you can do a comparison in flight. We are very focused on our engines, because really bad things happen if it stops working!
So I was wondering if anyone has used this in the Crossfire, I have read all the info on their web site and am leaning toward using it, just wondering if any one else has tried it?
So i have had the Microlon in for about three months, i think the engine is quieter at idle, but that is subjective! As for the temps I think I got a 5-10 degree reduction in oil temp at a steady 80 mph on the interstate with an outside temp of approximately 85 F. So not cheap but i feel even a little help in less engine ware is worth it.
Dan
Dan
