blower motor won't shut off leads to no start
Old Feb 21, 2018 | 05:38 AM
Default Re: blower motor won't shut off leads to no start
Originally Posted by Lyn
so does that rule out a bad relay?
Yea, pretty much.
Old Feb 21, 2018 | 09:08 AM
Lyn's Avatar
Lyn
banging my head on my desk right now lol....
Old Feb 21, 2018 | 09:40 PM
Yes I waited for several minutes with the key on as suggested When the key is turned to on the engine fan does not come on at all.....so what does that mean?
It means that the ECM must be powering up along with the Fan module OR that NEITHER are powering up. Given that the only thing needed to power up the fan module is the ignition switch, and that you have battery power for lights - I'd say it's fair to assume that the ECU is powering up and that the RCM is fine.
A real "no crank" that is, no engagement of the starter, given what we know, would seem to be to be one of these:
1) Clutch switch open (does not exist on automatics)
2) Bad pulse module (rare but it happens)
3) Defective ECM (don't think I've ever heard of one failing, least not in this way)
4) SKREEM module-related issue (disconnect battery 30 seconds, reconnect, if the starter engages and car starts and stalls three times, then you get no starter again - you have a SKREEM-related issue, PERIOD. End of discussion. ).
Here's a trick: Turn headlights on (make someone stand in front of the car so you can SEE the ligths shine). Hit key to start - if the lights dim a lot but you get no starter engagement, you have a fundamental issue (bad battery, really bad battery cable connection, etc.) - should be easy to find that one.
Old Feb 22, 2018 | 01:26 PM
I was told way back that the RIP for your wrecked 2005 car and all others like it means Rest In Pieces.
As mentioned previously, the problem likely lies in the SKREEM system somewhere, the chip in the fob has been lost, the connection from the ignition switch to the SKREEM has been broken or the SKREEM itself is toast.
That is where I would be looking.
Old Feb 22, 2018 | 04:07 PM
Lyn's Avatar
Lyn
you have all been wonderful and patient with a newbie....going to try the headlight trick and I will keep you all posted on what the outcome is...THANK YOU
x1xsinisterx1x
Aug 24, 2015 07:31 PM
2andym
Jun 16, 2014 10:08 PM
Jangel
Oct 31, 2010 09:36 AM
Crossfire725
Oct 14, 2010 12:16 PM
cdub
May 9, 2007 10:06 AM
