Engine, Exhaust, Transmission and DifferentialPost questions here that have to do with the engine, cooling system, air intake, exhaust, Transmission and Differential
I’ve noticed over the past couple of weeks a small, but, persistent fluid leak from my 2005. It appears to be coming from behind the wheel on the passenger side. I’m starting to work on the hydraulics for the top that are leaking & I’m wondering if it’s that simple or if it could be something else. I don’t have any codes, the car had its 90k mile service a few months ago. Any thoughts before I take her to our mechanic?
Thanks,
- Brian
It could be windshield washer fluid coming from a cracked reservoir.
See here. CLICK
I don’t see any evidence of wiper fluid leakage... I’ll take her to our mechanic ASAP. I did drive her today and didn’t have any problems with the engine or the transmission...
It's best to identify what type of fluid it is to locate the problem
That's how you do it. WHAT is leaking? If it is on the concrete floor, it is a simple matter to identify it.
People make things SO much harder than they really are. I learned this lesson at age 21 as a beginning electronics technician. "Mark, stop letting simple things intimidate you, use your basic senses and work backward from there." This lesson has served me well for 39 years.
Does that mean you have been going backwards for 39 years?
try to identify what type off fluid it is eg: water, trans oil, brake, steering etc then you will know where to look.
Good advice from both posts! Use your sense of taste to identify what the fluid is; each of the fluids has a distinctive taste.
I’m pretty sure that it’s transmission fluid. It matches the stories of a few drops turning into more & more over a few months. I’ll look into that and, as always, I appreciate the information and thoughts.
1) Did you lift the whole car up?
2) Any idea what the other picture shows? Is there a hose around there that has a wrapping on it? If so, does it need to be fixed, or, can I simply remove it?
3) What tool did you use to remove the part? My number of car tools are limited.
4) Anything that I’ll need to do with the computer?
