Oil level?
Oil was changed in April. It seems the oil is over the hash mark sometimes, but overfill light is not on. Is oil supposed to be checked cold or hot? Gas pump didn't shut off overfilled, car smell like gas, opened back panel found a fuel line laying in bottom of fender, feels like a pad at the bottom of well, car smells like gas all the time, any ways to neutralize the smell and is the hose supposed to be connected to a tube to exit vehicle
Well, first of all, welcome to CrossfireForum.
Most shops do overfill the oil, as the manual instructs a fill of 8.5 quarts where an even 8 quarts seems better, I've been doing 8 quarts for all three cars since 2009.
I do not know what 'back panel' you are talking about. The overflow drain hose from the filler area dangles from under the car and overflow drips on the ground. When my car smelled like gas from time to time, I found gas seeping from the seam between the two halves of the fuel pump so I replaced the fuel pump.
cgs0409
Mar 12, 2012 05:37 PM
HarleyGuy
Jun 8, 2011 07:47 AM
