Confounding
Old Jun 18, 2024 | 08:23 PM
Default Re: Confounding
I don't remember the inside of mine looking like that. If you squeeze the part does the crack move?
Old Jun 18, 2024 | 11:09 PM
Originally Posted by Rando72
Is that the 90 degree elbow below the MAF sensor before the Throttle body? Looks like something 'floating' in there (plastic?). The 90 degree elbow has (normally) baffles, looked like someone might have done the MOD for the elbow that reduced airflow (part of the MAF de-screen/elbow de-baffle). I can't place that photo part anywhere else. Good luck!
Old Jun 25, 2024 | 04:59 PM
Rando72's Avatar
Not sure, but it does not move and there is no space to place a screwdriver blade between. Another symptom is that the exhaust when it does run gets abnormally hot...to the point of smoking. Could it be that this whole issue is being caused by a totally clogged catalytic converter? And if so, how the heck do I figure out which one of the four is bad? Thanks for all of you guys comments. I am no ready to give up on this yet...(getting close)
Old Jun 26, 2024 | 02:37 AM
It might be a bad cat.
Check out this article from MagnaFlow:
Catalytic converter symptoms
Gary333
Apr 8, 2024 12:12 AM
Durgalar
Oct 25, 2022 10:59 PM
thaiexpat
25
Oct 13, 2022 08:01 AM
Staterules9
21
Mar 25, 2019 12:43 PM
CustomCrossfire2005
Jun 6, 2018 11:12 PM
