Europe Serving all countries of the European continent.
Engine diagnostics
Old Mar 25, 2018 | 04:24 AM
jamesmcaleer's Avatar
Default Engine diagnostics
Hi everyone, is the crossfire diagnostic reader obd 11, regards, Teak
Old Mar 25, 2018 | 07:23 AM
Default Re: Engine diagnostics
Yes. you will need an OBD II reader.
I highly recommend the Launch CRP123, not cheap, but will do air bag resets unlike most.
Old Mar 25, 2018 | 07:53 AM
Hi ala_xfire,thanks for your help and reply so quickly , Regards, Teak
Old Nov 19, 2019 | 01:32 PM
THETESTER's Avatar
Hi Teak
Did you get one of the scanners as suggested by ala_X fire?
I am looking into them now as I expect to fail my MOT emissions in January. Would be nice to have a heads-up prior to the test itself.
Cheers Mark
Old Nov 19, 2019 | 02:59 PM
[QUOTE=THETESTER;932805]Hi Teak
Hi there Mark, yes, I bought a scanner, I live in the UK and got one from Europarts, it was only about £20 ish, important to note it is only basic, but it does reset my code easily enough, let me know how you get on, I had to buy the secondary airpump, it cost $200 with an 18 month guarantee through eBay, I bought it from the USA
Old Dec 6, 2019 | 01:37 PM
THETESTER's Avatar
Hi Teak
Still looking for the most suitable scanner. None seem to mention anything about reading the emissions though. Do you know if yours from Europarts would read the emissions data? What was the stock/part number for the one you purchased?
Cheers
Mark
Old Dec 6, 2019 | 02:09 PM
Originally Posted by THETESTER
Hi Teak
Cheers
Mark
My BlueDriver shows each of the emissions tests that needs to be corrected, my Innova just says the total emission tests are OK or not OK.
I have five scanners total, the simple Ultragage, an Innova 3100, a cheap Elm 327, the BlueDriver ($100) and a Vident iLink 410. The BlueDriver is the one I play with using my iPad.
I have not used the Vident at all it says it can do a lot but I have yet to prove it. It only does some tests on some vehicles, I have yet to test it on the Crossfire.
These scanners tend to claim they can do all sorts of tests but often can only do a fraction of what they claim.
My Chrysler 300 did better than the Innova when using it’s own built in scanner.
Old Dec 6, 2019 | 02:38 PM
THETESTER's Avatar
That seems to be the problem, claim to do everything possible, but in reality do very little.
Old Dec 6, 2019 | 03:53 PM
Hi Teak
Cheers
Mark
Hi Mark, I`ve not got the reader here to check , but I trawled back through my old receipts, and found this as below, I hope this helps
553997350 Streetwize OBDII Fault Code Reader
Link below
https://www.eurocarparts.com/p/stree...ader-553997350
ala_xfire
Other Cars Etc
Apr 20, 2013 07:40 AM
AllEuro
Oct 7, 2010 12:38 PM
TechnoMage
Feb 6, 2010 02:57 AM
AtomHeart
May 4, 2008 01:31 AM
bflinn
Dec 30, 2007 10:14 AM
