Changing the corner lights
Old Nov 21, 2006 | 05:50 PM
ViffeR's Avatar
Question Changing the corner lights
Can anyone tell me if the corner marker lights at the top corners of the headlight assembly be changed with out removing the entire light housing? I plan on replacing them with ultra white LED's but am hoping I don't have to remove the light assemblies again!
Thanks!
Old Nov 21, 2006 | 08:39 PM
former NXMX5's Avatar
Default Re: Changing the corner lights
remove them again (?)
yup, you can replace them without removing the headlight assemblies --
Old Nov 21, 2006 | 08:46 PM
marauderroy's Avatar
There W5W bulbs (same base as 194), It's tight but you can get them out. You need to turn the socket then pull them straight back. The bulbs just slide in/out of the socket.
Old Nov 21, 2006 | 11:57 PM
stryfox's Avatar
194 style bulbs, turn counterclockwise and pull straight back. tight but I did it without removing headlamp.
Old Nov 22, 2006 | 05:09 PM
ViffeR's Avatar
Excellent, Thanks guys! let me tell you, it is NO FUN getting the head light assemblies out. I dropped the retaining clip for the drivers side head light into the housing and had to take the whole thing out to retrieve the clip...
PNA
Nov 12, 2020 04:44 PM
tom2112
Dec 1, 2015 09:02 AM
waldig
Sep 2, 2015 11:02 AM
skeet370
Jul 18, 2015 01:02 PM
JEFASOLD
Jul 15, 2015 02:32 PM
