Removing wires from low beams
Old Feb 24, 2010 | 09:37 PM
jediracer's Avatar
Default Removing wires from low beams
I must be tired or this thing is smarter than me! i tried pulling the connectors from my low-beams and they just won't come off! Any tips or suggestions as to how to overcome this? The car is only a 2006. they can't be that stuck..........or can they?
Old Feb 24, 2010 | 09:41 PM
TX_xfire's Avatar
Default Re: Removing wires from low beams
I had the same problem. Take the clip off first so you can get a good grip on the plug and bulb.
Old Feb 24, 2010 | 09:43 PM
tighed1's Avatar
It can be a real PITA.
Just keep squeezin' the release clip and keep wiggle'n the connector.
Old Feb 24, 2010 | 10:11 PM
jediracer's Avatar
I canget the clip off and the assembly comes out, But I was afraid to remove it with the wires still attached. They don't look like they extend that far. Now what release clip are you referring to? The clip that holds the bulb in?
Old Feb 24, 2010 | 11:28 PM
chambs's Avatar
yeah this is a real b*tch for me, i have been pulling on the black wire connector for the longest time, and it wont come out. all i see is the light reflecting on the wall going all over the place. My problem is weird tho...i can get the light to turn on by pushing on the wire on the back of the bulb, and then when i sit for a while with the lights off....turn em on, i can watch the light go out, is this a loose connection?
Old Feb 25, 2010 | 07:43 AM
danimal's Avatar
James, there is no release clip for the wiring harness.....just the wire clip to hold the bulb in. The easiest way (that I found) is to leave the bulb clipped into the housing, and get a pair of long, needle-nosed pliers and grab the back of the black plastic connector and pull hard. If you start twisting it, all that you are going to do is break the connector. It does come off but takes some muscle.
Old Feb 25, 2010 | 10:01 AM
jediracer's Avatar
Thanks Dan
I will give another try today. I just didn't know how hard I had to pull. Nothing like breaking something you were supposed to be fixing!.
Old Jun 27, 2010 | 11:32 PM
Schrudds's Avatar
I had the same problem and I broke the connector. I went to a Chrysler dealer and they could not find the connector part number. Has anyone purchased a new connector. I NEED to know the part numbers.
Old Jun 28, 2010 | 07:47 AM
maxcichon's Avatar
If all else fails, you can just clip the wires off and install regular 1/4" spade (female) connectors temporarily. They will fit the bulb perfectly.
I think the connector is part of a far larger wiring harness and will not come alone.
Old Jun 28, 2010 | 04:55 PM
Infinite's Avatar
They seem to get stuck over time. Just pull really really really hard.
once you get them off put some dielectric grease on the so it doesnt happen again
Old Jun 28, 2010 | 05:27 PM
maxcichon's Avatar
Too late, bro'. He already broke it!
RED DOG
May 4, 2019 08:05 AM
Hoppy
Dec 7, 2018 07:36 AM
gp1200x
Dec 6, 2015 12:59 PM
pioneer4x4
Jul 27, 2015 02:04 PM
RED DOG
Jul 21, 2015 07:58 AM
