Will these work without resistor?...
....2 x 12V Super White 168/194/2825/T10 LED Rear License Plate Light Bulbs | eBay
I'm assuming these will trigger the "failed bulb lamp"...?
They will not fit. You need a "Festoon" type bulb, 37 mm (?) I think.
http://www.ebay.com/itm/Super-Red-1-...item1e658f05b6
Of course, these are red, look for white ones.
http://autolumination.com/festoon.htm
Maxichon is correct and yes, it will trigger the "light out" lamp
Here:http://www.ebay.com/itm/2pcs-Super-B...item27c1fb5f79
Thanks guys for the info....even though they were advertised under "Chrysler Crossfire", the seller makes available a compatibility link....the link says they are not compatible for Crossfires....I'm curious about the last link provided for the SLK320 advertsing "no error". Built in resistor maybe?
ja.nko
Jul 10, 2015 03:21 PM
