led lights behind the dash
Old Jul 2, 2012 | 09:24 PM
natedog93's Avatar
Default led lights behind the dash
My 2005 limited roadster has those ugly green led lights behind the dash, and i want to change them out for a red led where can i buy those?
Old Jul 3, 2012 | 11:04 AM
dtinker's Avatar
Default Re: led lights behind the dash
I don't think it as easy as changing the bulbs. Do a search " changing color of dash lights" , pretty big job as I remember.
Old Jul 3, 2012 | 11:27 AM
DTinker is correct. simply switching to red will give you a nasty purplish color because it is not the bulbs that give it the green color, the actual overlay has green integrated into the piece. Apparently to change the color, you need to remove the entire cluster, take it apart, remove the overlay, and very gently sand off the green coloring, then replace the bulbs.
There is a thread that details the entire process if you search for it. Should take a good tech a few hours...
Old Jul 8, 2012 | 06:47 AM
natedog93's Avatar
oh well crap that doesn't sound to fun yeah im figuring out everything on the crossfire is a big pain to work on.
Thanks guys for the replies i look into it a bit more!
Old Jul 13, 2012 | 04:49 AM
Merry Browen's Avatar
I took them out to the garage for installation one at a time when ready to install. Mine stuck really well and have not moved. When installing the LED strips, I was very careful not to touch the adhesive side of the strips and only peeled a little of the paper backing at a time.
led light bulbs
led lighting downlights
LED Fluorescent Replacement
Old Dec 28, 2012 | 11:24 AM
Thermor's Avatar
Originally Posted by Merry Browen
I took them out to the garage for installation led one at a time when ready to install. Mine stuck really well and have not moved. When installing the LED strips, I was very careful not to touch the adhesive side of the strips and only peeled a little of the paper backing at a time.
I want to purchase affordable led headligths do you know some reliable site?
Adrian_X
Nov 9, 2017 08:49 AM
maxcichon
Jul 8, 2016 08:28 AM
xfClifford
27
Nov 10, 2015 10:08 PM
glover
U.K.
Oct 1, 2015 03:34 AM
Blackout317
Jul 7, 2015 08:38 PM
