FEELER: SRT-6.com groupbuy ViS Racing carbon fiber hood for $500-$650 USD
  #181 (permalink)
Old 11-26-2013, 07:52 PM
FUBU's Avatar
Default Re: FEELER: SRT-6.com groupbuy ViS Racing carbon fiber hood for $500-$650 USD
Thanks for the comments. I have already sent them off. I will start building a real list now, not just a feeler. The prototype design will we the waldig+firepower+srt-6.com mix. Last design is always shown in first post.
I will start a new thread tomorrow and only add people to the list who will send me their full details. If we then can come up to the right number we are launching this. Then Fred will be needing a SRT-6 with DCAI to go down there. I recieved a letter by Steve B, member here, who are willing to go there and let them do some measurements. I also have a srt-6 hood that they will make the mold of.
  #182 (permalink)
Old 11-26-2013, 08:15 PM
meh03's Avatar
Has ViS indicated how long the process will take? Are we talking about a Christmas present or a few months?
  #183 (permalink)
Old 11-26-2013, 08:17 PM
Mrmiata's Avatar
Good question! Kinda determines whether I'm shopping Zales or Walmart for the wife..
  #184 (permalink)
Old 11-26-2013, 08:27 PM
FUBU's Avatar
Did i not mention this? sorry then, he have said 6 weeks of production time. It may be less or more. Collecting names tomorrow. So be prepared
  #185 (permalink)
Old 11-26-2013, 08:28 PM
FUBU's Avatar
Hahahaa. Love it!
  #186 (permalink)
Old 11-26-2013, 08:48 PM
Mrmiata's Avatar
Okay.. "Just to make sure".. this is where we are at..correct..? And I'm going to guess this new "list" will still allow an out (respectable out..LOL) if the design for whatever reason takes an undesirable turn? Oh..and see if there is a cheaper shipping (2 in one double box) at the same Address..
  #187 (permalink)
Old 11-27-2013, 10:31 AM
sk8erjosh09's Avatar
I want to be in but I'm going to go down there first to make sure if it will fit or not. So count me out until they have one on hand for me to test fit down there.
  #188 (permalink)
Old 11-27-2013, 01:59 PM
FUBU's Avatar
So believe it or not I may have come up with a smart idea. take a look at the pictures and let me know your thoughts..
By doing this we will have maximum function and good design. the raising of the hood in the back will me max ½ inch, just enough to let air run out.
Hit me with some feedback.
P.S. rearview without the reverse scoop.
  #189 (permalink)
Old 11-27-2013, 02:11 PM
Mrmiata's Avatar
+1 rear view without the reverse scoop..
  #190 (permalink)
Old 11-27-2013, 03:19 PM
meh03's Avatar
+2 no rear center scoop
  #191 (permalink)
Old 11-27-2013, 03:57 PM
velociabstract's Avatar
No rear scoop please.
Les
  #192 (permalink)
Old 11-27-2013, 04:01 PM
FUBU's Avatar
The heat extraction from that mid reverse scoop would be immense. Also, it will be minimal changes to the design. Take another look at the pic below.
Attachment 30132
  #193 (permalink)
Old 11-27-2013, 04:05 PM
FUBU's Avatar
Les, meh, miata, and you other guys. Are we willing to sacrifice the gains/functions for due to design? This one is up for you to decide now. Either the firepower vents with spine AND the reverse scoop OR simply just the firepower vents with spine.
What do we prefer?
  #194 (permalink)
Old 11-27-2013, 04:31 PM
Mrmiata's Avatar
Thought I had read in this thread the area at the base of the windshield was a high pressure zone.. so don't see where heated air would get to escape other than low speeds and Idle..
  #195 (permalink)
Old 11-27-2013, 04:39 PM
FUBU's Avatar
Well, the actual opening of the rear vent will be huge and almost centered over the SC. The opening that we will see is by the windshield, or where the lines stop.
But confirm the above and we will dump the idea totally and just go for the firepower spine vents.
  #196 (permalink)
Old 11-27-2013, 04:46 PM
Mrmiata's Avatar
Originally Posted by hustler316
Air will get sucked back down into the engine not pulled out, there is a high pressure system that is created by the windshield. Since there is a seal on the back of the hood no air escapes from the rear out and over, instead it goes down and under the car. If you vent the rear with hopes of air escaping it simply will not happen unless you are not moving, then it will in fact escape from the rear. The further forward you move them as long as they are behind the radiator the better your chances of air escaping becomes. The best way to effect cooling of he engine is to get air to flow through the radiator with the least amount of restriction. This includes pressure systems, vent the front so air flows through the radiator and out the hood is the best method for this.
^^^ This..
  #197 (permalink)
Old 11-27-2013, 05:19 PM
FUBU's Avatar
OKay that is good enough for me.
  #198 (permalink)
Old 11-27-2013, 05:27 PM
My observations are exactly what Hustler said. I've run with the rubber strip removed, belly pan removed, both removed etc. Anything over barely moving and air will enter instead of exit. The nose of my car lifts at high speed and allowing air to enter at the base of the windshield only made it worse. Float it past VIS for your peace of mind, I'm sure of the answer. If the final design has it, I'll plug it.
Les
  #199 (permalink)
Old 11-27-2013, 05:52 PM
FUBU's Avatar
Les
" If the final design has it, I'll plug it."
well if I write above that his answer is good enough for me no need even to ask. I am skipping it. I am updating the first post as we speak.
  #200 (permalink)
Old 11-27-2013, 06:26 PM
meh03's Avatar
Attachment 30135
Attachment 30132
Hey guys, what I was trying to say earlier is if we can get heat out of the rear of the engine then lets do that. But not like the center vent. The heat is not above the SC it is at the headers. If we can get heat out of the engine bay by putting small exhaust vents by the headers, then lets look at that. Woody would be the one to answer this. If the air flow in the engine bay will not exit from the top then nix it. If we can get some heat out by putting vents at the back of the hood by the headers, then lets look at that. The current (only front vents) is great and everybody loves it so stay with that unless someone with much more knowledge than I can chime in and let us know if rear vents will help.
Quick Reply: FEELER: SRT-6.com groupbuy ViS Racing carbon fiber hood for $500-$650 USD
