Adjust/aim headlights
Old Aug 27, 2014 | 09:15 PM
gbono2's Avatar
Default Adjust/aim headlights
Hey folks --- I need some help. It seems both headlights on our '05 XF are aimed too low for safe night time driving. How do I adjust them? Is this possible? Any information would be greatly appreciated.
Old Aug 27, 2014 | 09:34 PM
Default Re: Adjust/aim headlights
The white **** on the back of each unit should raise and lower them.
Be aware that you can overdo it and the adjustment screw will pop out of the socket.
Before using these adjustment ***** however, ensure all the H7 bulbs are properly seated
with the little extension on the bulb in the notch.
You can use a small mirror and a flashlight to check this.
Old Aug 27, 2014 | 09:50 PM
gbono2's Avatar
thanks George
For checking the seating of the bulbs, can it be done w/headlights installed? Would you mind explaining the procedure a little more?
Old Aug 28, 2014 | 07:10 AM
Yes, with headlights installed. Easiest way to check the seating is to just grasp the bulb connector and try to twist it left / right.
It should not twist, but if it does, twist until you hear/feel the tab go into the slot.
See the bulb tab in the below picture.
Also refer to : https://www.crossfireforum.org/forum...light-bulb.pdf
Old Oct 25, 2014 | 11:36 AM
janaiy's Avatar
on my left headlight my son tried to raise the headlight and of course it popped out of the socket. Now how can I fix this mess?
Old Oct 25, 2014 | 12:29 PM
janaiy's Avatar
thanks, already made it happen proud of myself
Old Mar 14, 2015 | 08:44 AM
KDW4Him's Avatar
Hi janaiy, which direction did you turn the adjuster to get it to "pop" back in, clockwise or counter-clockwise?
James1549 might you know as well?
I suspect the previous owner did some tweaking and I have a left drooping aim. If you look very closely you can see it as compared to the other side.
Old Mar 14, 2015 | 08:39 PM
KDW4Him's Avatar
"Popped" it back in all is fine.
Old Oct 4, 2018 | 09:36 PM
Nunyadam's Avatar
In my case the passenger side low beam was out of the socket.
The drivers side needed adjustment up, and in.
up was easy (turn the ****), in required wood working skill. The tab on the top outer corner is busted off from a wreck in the past, for the moment I cut small piece of 1"x1" maple and wedged it behind it.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
