Brake light relay
Old Sep 8, 2015 | 10:14 PM
8ighth Wonder's Avatar
Default Brake light relay
Can anyone tell me the location of the brake light relay? I'm looking under the hood and can't find it.
Old Sep 8, 2015 | 10:47 PM
Default Re: Brake light relay
It's in the fuse box under the hood.
Electrical components locator
Old Sep 9, 2015 | 10:53 AM
xfClifford's Avatar
Drivers side, in the fuse box, you'll need to take off not only the first cover but the inner cover. There are fuses hidden under that as well. I just replaced mine.
Old Sep 9, 2015 | 11:01 AM
Thank you both. It turned out not to be the relay v but the 50 amp BAS fuse next to the radiator fan fuse that blew and killed my brake lights.
Old Dec 12, 2015 | 01:17 PM
barber's Avatar
hi,
Im trying to replace my brake relay.. When you say there is a second inner layer could you be a little more specific. Im lost and trying to do this myself.And how did you take it out. any information on how you did this would be much appreciated...
Old Dec 12, 2015 | 01:22 PM
Originally Posted by barber
hi,
Lift the fuse box up that's under the hood.
Old Dec 12, 2015 | 01:26 PM
barber's Avatar
yes.. all or out...Thanks for the prompt response..
Old Dec 12, 2015 | 01:27 PM
barber's Avatar
Sorry all brake lights are out..turn signals work.
Old Dec 12, 2015 | 05:23 PM
hi,
When the top cover of the fuse box is removed, you can see 2 rows of fuses, surrounded by another plastic cover. The second cover has detents at the front and both sides, press in on them and pull up on the cover from the front.
Once this cover is removed, you will see two black relays at the firewall.
The brake relay is the one toward the center of the car, the other relay is the locking relay.
Old Dec 12, 2015 | 10:33 PM
Good description, I sent you the number to my shop in case you needed more info. If this doesn't fix your brake lights check the major fuses on the left hand side of the engine compartment, it's 3 fuses in the main power distribution location.
Old Dec 13, 2015 | 09:40 AM
barber's Avatar
omg.... thank you to the moon and back.. My lights now work.. Im about to wash her and take a long over due ride..Thanks again....wooooo!!!!!!
Old Dec 13, 2015 | 10:44 AM
Was that fuse the culprit?
Old Dec 13, 2015 | 05:57 PM
If you took off either the 1st fuse cover and the second (lower) cover, or just the top cover, make real sure you set both back correctly and securely. If you don't, water can and will get into that box and wreck havoc over time.
Old Dec 15, 2015 | 12:37 PM
He thinks he's answered, you are supposed to know.
Old Dec 15, 2015 | 01:42 PM
He thinks he' answered, you are supposed to know.
I guess so, lol.
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
PNA
Jul 27, 2015 12:28 PM
westonrose
Jul 14, 2015 11:25 PM
Blackout317
Jul 7, 2015 08:38 PM
