SRT Headllight Bulb Change
Old Apr 14, 2024 | 03:18 PM
Default SRT Headllight Bulb Change
The passenger low beam headlight bulb died last fall just when the car was put away, I assumed that I would have time to fix it before spring - wrong assumption.
Removing the coolant tank would not help so I remove the rubber cap and pulled the plug using a small hemostat I use for hook removal when fly fishing, it fit nicely in the gap between the insulation of the two terminals. Needle nose pliers slipped to easily. The bulb went into place easily, reassembled and job done.
While doing one bulb I thought I would change the other, this was not going to be as easy, the air pump and fan controller were in the way and would present a major problem. The car must have been assembled around the drivers side headlight unit. So the headlight unit is coming out, This operation has been described as both easy and tricky, we will find out and I'll continue when this is done and add some photos as well. I sealed the fog light access doors with black Gorilla tape to stop them falling open again, we'll see how strong they are on there.
I am changing both low beam bulbs as both blew within two weeks of one another on my old NA. In Canada we have daytime running lights so the low beams are on all the time the car is running.
I intend to change the high beams while I am in there, I changed them once before without removing the headlight units. I may not bother though as I am getting lazier by the day.
I am using Philips Night Guide Platinum NGPB1 bulbs on the low beams and Bosch bulbs for the high beams, I used Sylvania bulbs previously.
Old Apr 14, 2024 | 03:57 PM
Default Re: SRT Headllight Bulb Change
I installed the LASFIT LED bulbs hoping they would last longer. I also use a hemostat.
Old Apr 15, 2024 | 02:04 AM
JSK's Avatar
JSK
I changed low beams on of the cars recently, I have a long pair of needle nose pliers that are angled and ground a notch into the blade of a medium sized flat blade screwdriver to maneuver the clip. Between the two tools I was able to avoid injuring the back of my hands.
Old Apr 19, 2024 | 11:05 PM
Edit
I got so lazy that when I saw the work to get the headlight out I gave up before l lost blood.
Instead I am going to instal a rear facing dashcam . Cars get hit from all angles, getting rear ended must be nearly half the crashes.
ZERACER
May 30, 2026 08:04 PM
romanylife
Sep 8, 2019 06:21 PM
francist44
Dec 23, 2014 10:28 AM
cg80
Oct 12, 2013 06:44 AM
xxfirerican
Nov 21, 2008 05:58 AM
