Dash issue - partial lighting only
Old Sep 6, 2025 | 03:13 PM
M.C's Avatar
M.C
Default Dash issue - partial lighting only
Has anyone seen something like this before?
Dash at day - max brightness
Dash at night - max brightness
The display is not lighting up in the centre left, all the speeds from 0-70 and the entire fuel gauge, including the needle.
I checked and It’s not the light dial, it stays like this from min to max, it’s just more obvious with it all lit up. Fuses are all good.
If anyone ran into this issue please let me know what it was and how you fixed it. I found nothing and the only thing left is to open up the dash to dig for the circuit board which I would really not want to do unless absolutely necessary 😂
Old Sep 6, 2025 | 04:23 PM
Default Re: Dash issue - partial lighting only
My guess would be a bulb out.
Old Sep 7, 2025 | 02:10 AM
Here's a video on how to change the bulbs. The plastic is old and brittle so take your time and try to use plastic trim tools instead of metal.
Old Sep 7, 2025 | 03:36 PM
M.C's Avatar
M.C
Thanks guys, will do that in the next few days. Those videos are a blessing to see, instantly makes a job 50% easier.
Might prebuy the bulbs now so I can do it in one day, delivery times are a joke in the UK unless they’re on Amazon and I still need to use the car.
The Left turn signal is also out now so hopefully new bulbs will fix it.
Old Sep 7, 2025 | 06:16 PM
BobG's Avatar
Good video that brought back memories of when I removed the instrument cluster years ago.
One tip: Be careful when playing around with bulbs after cluster removal. There are some empty, unused sockets, so it's easy to put a bulb in one of them. AMHIK. My suggestion is that you mark all unused sockets with masking tape before doing any bulb swaps.
Old Sep 8, 2025 | 11:55 AM
If the left signal (indicator on the speedo, front signal and rear signal) - if ALL do not light up at all, the issue is the multifunction switch.
As our cars age, this has become more and more common.
Old Oct 4, 2025 | 07:54 AM
M.C's Avatar
M.C
Update.
So it was actually one of the brake bulbs in the back causing this. Someone noticed the double filament was not lighting up when the brake pedal was pressed and we opened the trunk and one on the bulbs was not put in right. Once we adjusted it the dash lighting went back to normal, the brake lights work and the bulb out warning is gone.
This car never stops surprising me 😂😂
Old Oct 4, 2025 | 11:13 PM
Update.
Thanks for the update!
Old Oct 5, 2025 | 09:01 AM
zip439's Avatar
The other warning light on your dash is the brakes pads. You best inspect the brakes and plan on replacement of the pads.
Old Apr 30, 2026 | 12:22 PM
M.C's Avatar
M.C
I believe that might be the handbrake as was parked when taking this. It’s definitely on the list though, surprisingly it’s not as bad on this car as on the 300c haha.
Squirrel Crusher
Apr 7, 2012 06:08 PM
Tee
Nov 14, 2011 05:20 AM
Montana Crossfire
Jun 10, 2009 11:27 AM
MAKIII
Oct 6, 2008 04:41 PM
blacklimitedcoupe
Mar 6, 2007 07:00 AM
