Instant Hot Water...
Old Nov 22, 2009 | 03:15 PM
Deborah Walker's Avatar
Default Instant Hot Water...
Hey, thinking about buying one of those Instant Hot Water spouts for my kitchen sink.... has anyone installed one of those??? Hard, Easy... do I need a plumber or just a handy guy????
Need one bad on my kitchen sink!
Deb
Old Nov 22, 2009 | 03:48 PM
Default Re: Instant Hot Water...
the hardest part is, you will need electricity under the sink, and most likely there isn't any. I had to run a line over and install an electrical box and plug for the the heater. The rest is just like installing a faucet, only easier. Good luck...
Old Nov 22, 2009 | 03:56 PM
Actually, since it's her kitchen sink if she has a disposal there will be power.
I've never installed one but seen them and they look pretty easy to install.
Old Nov 22, 2009 | 04:02 PM
usually they run that wire direct to disposal, and it is on a switch. You would still have to run a wire that is live all the time, not just on the switch...
Old Nov 22, 2009 | 04:12 PM
David Woolrage's Avatar
As the other fellow told you, they're easy to install but you need a hole in the sink or have to drill one.
If you like you can use the dish washer anti-siphon hole and hook the 2 ends together and clamp them so they don't leak!
Electricity under the sink is ALWAYS available at least in homes built in the last 5~10 years for the garbage disposal-dish washer, etc. If you have a garbage disposal in your sink it,s plugged into a switched outlet so DON"T USE THE SWITCHED OUTLET! Rather, put a multi-tap unit into the non switched outlet and plug in the hot water dispenser.
(You can usually tell a switched outlet because it's installed upside down, ie, the ground stud is up instead of down like thew other outlets!)
Hope this helps!
Dave Woolrage _/)***
Nov 11, 2015 05:22 AM
nataliefs
Oct 5, 2015 01:03 PM
Oct 1, 2015 01:42 AM
waldig
Sep 17, 2015 10:35 AM
PA/XFIRE
Sep 5, 2015 01:25 PM
