12v Supply to the Trunk / Boot
Old Apr 7, 2016 | 02:38 PM
Roody's Avatar
Default 12v Supply to the Trunk / Boot
Hi All
can anyone tell me how to remove the main light switch as I want to get to the rear so I can piggy back the 12v feed so I can run a cable to the trunk / boot . Take it if was to do this , when the ignition is turned on / of the 12v feed to the rear will also be on / off. Unless any other ideas where can pick a feed up to do the same .Reason being I don't want to run a feed direct from the battery and have a constant feed when car is turned off.
There is I take it a 12v feed to the rear of the switch ???
Thanks in anticipation
Roody
Old Apr 8, 2016 | 05:39 PM
Default Re: 12v Supply to the Trunk / Boot
How much current do you expect to require for what you are doing? If we are talking, say, 10 amps or less, use an "add a tap" in the underhood fuse box, pick one of the switch-supplied fuses.
Add A Circuit Fuse Tap Standard Blade Fuse Holder ATO ACU 12/24V 15A - Walmart.com
Old Apr 9, 2016 | 06:40 AM
Roody's Avatar
Hi Ya
Thanks for the advice , but just took it to the local Electrical Auto Tech in the end . The 12v feed was required to run an illuminated wind restrictor from King Penn and the auto controls that I got as an add on extra. Not done the wiring yet but at least I now have a feed In the trunk which means I don't have to run with the lights on to power the units..
But thanks for getting back to me .
Roody
Old Apr 9, 2016 | 11:49 AM
I just installed my WR two weeks ago. I tapped a fuse in the box I mentioned and ran the wire to the back myself. There is a super-easy route from the fuse box to the inside of the cabin, I need to make a video of how to do it.
Super easy and it exists in all models and years of Crossfires.
(Sorry you spend money on something like THAT!)
Old Apr 9, 2016 | 11:50 AM
And yea, there was NO WAY I was going to wire to lights - how can I leave it running in parking lots if I have all those damn lights on? Glad I'm not the only one who thought it necessary to do this.............
Old Apr 9, 2016 | 05:39 PM
There is UNSWITCHED 20 amps ( from 2 different fuses ) available at the locking pump in the trunk on connector C2 pins 2 & 4 :
Unfortunately, I don't see any switched connections .......
Old Apr 11, 2016 | 04:01 AM
Roody's Avatar
Hi All
Don't know whats up but now have no brake lights , is there a brake light fuse . Windrestictor from King Penn worked for a while and was wired as diagram. HELP.
Roody
Old Apr 11, 2016 | 10:50 AM
If you are going to pursue this, groping in the dark is a waste of time. Download the own'ers manual and service manual so you know what you are doing.
Here you go:
https://www.crossfireforum.org/forum...ollection.html
To answer your question, it's fuse 2 in the ICM. At least in '05 it was, they changed some fuses around under the hood, but I think the ICM stayed the same all thru production.
Old Apr 12, 2016 | 03:48 AM
Roody's Avatar
Hi All
Thanks for the response's now all sorted and the restrictor up and running .
Thanks Again.
Roody
