Manual shift knobs
Old Jan 22, 2008 | 07:13 AM
Shawnkey's Avatar
Default Manual shift *****
What have you changed your shift **** to? I've seen the Indy-Cator one, and I like it, I just don't want to go that far into it. What I would like is a silver ball with a black spot on the top, the have AMG in silver in the black spot.
Post pics
Old Jan 22, 2008 | 09:13 AM
former NXMX5's Avatar
Default Re: Manual shift *****
this is mine... sounds perfect for you
http://www.shopmomo.com/race.html
Old Jan 22, 2008 | 09:16 AM
found a pic:
Old Jan 22, 2008 | 09:27 PM
DanielNTX's Avatar
If I didn't have the Indy-cator, it would be this one: http://www.mavenmotorsports.com/
The Maven Mark 1
The Maven Mark One shift **** was designed by enthusiasts for enthusiasts. The weight, material, shape and texture were all optimized to deliver the finest and most precise shifting action of any **** on the market.
Specifications
Weight - Precision balanced to 472g (1.04lbs). The mass is concentrated at the top of the **** to maximize the pendulum effect while changing gears.
Material - 100% solid medical-grade stainless steel. This alloy will not tarnish or leave a metallic smell on your hands like other *****. It's surface hardness is much higher than aluminum to resist scratching.
Shape - Over 30 revisions were made before the final shape was realized. The contoured shape fits snugly in the palm of your hand. The overall height has been reduced to shorten the shift throw.
Texture - Spun finish controlled to within 64 micro inches (less than 0.000064"). Please see some of the enlarged shots in the gallery for a closer look.
Fitment - The Maven Mark One uses a machine-cut thread to ensure a 100% OEM fitment. The standard M10 (metric 10mm) thread will fit a variety of cars. Many imported models use this style of thread; please see the product page for a list of tested vehicles.
Old Jan 23, 2008 | 09:01 AM
Shawnkey's Avatar
I'm looking for more....hard to explain
Old Jan 23, 2008 | 10:29 AM
Mike-in-Orange's Avatar
I like how the factory **** not only matches the rest of the silver trim on my Limited Roadster, both inside and out, but how it also has that line cutting through it that follows the rest of the design of the car. So I'm keeping it. But what I did do was to take a very fine artists brush and some Aero Blue touch up paint and paint inside the numbers and lines of the shift pattern. Now it really matches my car!
Old Jan 23, 2008 | 01:15 PM
Shawnkey's Avatar
I like that Idea, nice job!
Old Jan 23, 2008 | 04:33 PM
Maxwell's Avatar
Post pics
I used a 2" alluminum ball from MC master, fits like a glove. only $12
Old Jan 23, 2008 | 08:09 PM
No Warning Shot's Avatar
Kinda like mine, only I did red numbers with a black pattern.
Old Jan 24, 2008 | 03:38 AM
ben47's Avatar
Did you read the last sentence in the third paragraph?
" It is not recommended for use on cars with lift type reverse lock outs."
I hope it doesn't come off in your hand....
Old Jan 24, 2008 | 03:40 AM
ben47's Avatar
Deleted, double post....
Old Jan 24, 2008 | 06:09 AM
its been 3+ years; no problems yet --
Old Jan 24, 2008 | 12:11 PM
XFiringInNC's Avatar
I don't think that this is talking about the Europen style reverse that requires you to lift up on the stick to get to the reverse gear.. I think it is talking about a lever that you have to pull up from under the stick in order to move the transmission into reverse, kind of like a Hurst shifter, I guess, but with a pull instead of a squeeze. Ours is not a lockout lever. It's just how the shift pattern works.
You know what I worry about when replacing the shift **** with one that doesn't have the shift pattern on it? When we go out and I leave the car to be valet parked... that the valet parker will put the car in 6th and toast my clutch or something. It's probably not very likely, but it's one of those irrational concerns that I have. I have learned never to underestimate the potential for stupidity.
Old Jan 24, 2008 | 12:13 PM
Having said that, I think I like this one: http://www.shopmomo.com/racair.html
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
crossfireusa
Oct 28, 2015 12:03 AM
jimf
Oct 10, 2015 10:22 AM
eatmycrackers
Sep 23, 2015 09:08 AM
