Anyone know the proper way to remove these rings?
Old May 26, 2008 | 10:26 AM
Default Anyone know the proper way to remove these rings?
Old May 26, 2008 | 10:38 AM
SRT6nTulsa's Avatar
Default Re: Anyone know the proper way to remove these rings?
Are you having problems with the aluminum door lock plungers?
Old May 26, 2008 | 10:43 AM
CALL911's Avatar
Not sure if this is the same as most other cars, but normally they affixed to the inside of the door panel at assembly by bending metal tabs over on the inside. I believe you'll have to remove the door panel to get them off.
Old May 26, 2008 | 11:27 AM
Nope, just replacing them with chrome ones.
Old May 26, 2008 | 03:40 PM
MannyTwoTwo's Avatar
Well, it wasn't the cleanest removal but since they were plastic I removed it "in pieces". Plus, I wasn't planning on putting them back in. The installation of the chrome piece wasn't a piece of cake either. It did not screw in so I tapped it in with a rubber mallet.
Good Luck...
Old May 26, 2008 | 05:54 PM
CrossfireLTD's Avatar
Cool Re: Anyone know the proper way to remove these rings?
Fp...Use a thin jewelers screwdriver (if you have one) and lightly pry around the rim and they will begin to come up. Once you see that it is coming up, use you fingers or a pair of small needle nose pliers and screw them out, they are threaded. If you are replacing them with the chrome surrounds from GAP (CTD, TVT, Chrometec) you may have to widen the opening just a bit. In my case the driver side went in without issue, but the passenger side I had to widen just a hair.
Old May 27, 2008 | 09:26 AM
snowtop57's Avatar
Where do you get the chrome ones?
Old May 27, 2008 | 10:46 AM
Blacklimitedcoupe here on the forum has very nice polished aluminum ones, but if you want chrome, I got them from this guy in Turkey. I found him on e-bay, but when I made him an offer he ask that I buy them from his site. I guess to avoid e-bay fees.
www.veltors.com
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
ritous1
Sep 26, 2015 01:27 PM
