Lighter removal, question
Old Sep 1, 2008 | 10:26 AM
ZORRO's Avatar
Default Lighter removal, question
How do I remove the lighter from this part?
Sorry the first shot is so blurry.
Old Sep 1, 2008 | 06:34 PM
Kurts's Avatar
Default Re: Lighter removal, question
Evenin', Zorro!
...and the blurry one is the one you need to see, it never fails!
Is the lighter body threaded? If it is then you need to get a pliers & twist the ring. It's definitely mounted from the rear...........
Old Sep 1, 2008 | 08:46 PM
ZORRO's Avatar
Originally Posted by Kurts
Evenin', Zorro!
I have taken 10 shots of this thing! The two things I can't seem to do is take it apart, or take its picture!
It is not threaded as far as I can tell. It is put together like a Chinese puzzle box. I have taken lighters out of more cars than I can remember. This one is like a bad joke. As you go through the manual it's in the drawings up till the point that you would need to see it. Then it just disappears.
Zorro
Old Sep 2, 2008 | 07:18 AM
calxfire's Avatar
Maybe go to a Chrysler dealer and try to order the lighter and see what picture comes up in their parts list if it's just the lighter item or if the whole thing is ordered as one piece. Just an option if you have the time and inclination.
Old Sep 2, 2008 | 09:42 AM
ZORRO's Avatar
Looks like I have to take it in one way or the other. I tried looking up the part at some of the on line parts sites and they don't even show a lighter. Hopefully the dealers book will, or maybe the service guy has had to replace one. I just want it out so I can paint the dash part.
Zorro
Old Sep 9, 2008 | 11:58 AM
ppro's Avatar
From the parts list it appears that is a single part number that does not break down into separate part numbers. Check part 05102786AA
-2 LIGHTER
05102786AA 1 C, Z S, X 29 EGX, EGZ DED, DGJ,
DGU
With housing
Old Sep 10, 2008 | 05:57 PM
Kurts's Avatar
-2 LIGHTER
DGU
With housing
Who would've thought it'd be one part!
Something new every day..........
Old Sep 11, 2008 | 05:05 AM
ppro's Avatar
That seems to be the trend. Our Volvo got tapped a couple years ago and there was one small crack that involved a single panel of plastic on the left tail light. I took out the panel (it snapped off easily) and went to the dealer for a new one. Wrong. I had to buy the whole assembly. With my club discount it was almost $200! And this was from a dealer that I had a personal and business relationship, and a parts guy that was my friend, so I know they didn't fleece me and sell me more than I needed. I was stunned. It was a huge waste of plastic and money.
At least here the part is relatively small and I can almost see why they'd make it one part...
Say, why the King Crimson avatar?
Old Sep 11, 2008 | 11:09 AM
rcompart's Avatar
If you have a right angle hook tool, take that and there are two tabs that you need to push in. While you are doing this, you need to be pushing the lighter out as well. It's a pretty brute force affair but don't' worry, the tabs are really resilient. We've pulled three of them out this way between myself and jonnyangel. Hope this helps. Are you painting your dash or did your lighter crap out on you?
Old Sep 11, 2008 | 05:08 PM
Kurts's Avatar
Evening, P!
Mostly 'cause it appears to be a graphical representation of way I usually feel at the end of another day in the world of Information Technology!
Or, because I think it looks fairly cool.
Either explanation will do !
I'm glad you recognize the cover!
Old Sep 13, 2008 | 12:18 PM
ZORRO's Avatar
I am painting the dash, or more likely having it painted. Are these two tabs the small black rectangular plastic ones you see when you look inside the lighter receptacle? What is a right angle hook tool? Like a dental tool?
Thanks
Zorro
Old Sep 13, 2008 | 05:42 PM
rcompart's Avatar
Thanks
Zorro
The black tabs are on the outside part of the lighter socket that hold it to the plastic fascia piece. A right angle hook tool is pretty much a small much that has the last half inch bent at a right angle to the rest of the shaft. You could use a dental pick tool too and those are sometimes for sale at automotive parts stores. YMMV
Good luck and hope it helps.
Old Sep 13, 2008 | 09:38 PM
ZORRO's Avatar
Nope, I do not get it. Must be over my head. WOW it's just a lighter. Why can't I just take it apart? Who designed this thing Satan?
Old Sep 13, 2008 | 09:42 PM
rcompart's Avatar
Take your thumb and push on the back of the thing as hard as you can and if the clips break on the lighter socket, I'll give you mine as I'm not using it anymore, just pay shipping. I can't believe it's that hard to get that little bugger out of there. I agree with you that Satan designed it though.
PNA
Nov 12, 2020 04:44 PM
LE Cross
Oct 17, 2016 06:35 AM
NORDVIK72
Aug 30, 2015 08:22 AM
NORDVIK72
Aug 25, 2015 11:43 PM
Josefigue
Jul 15, 2015 04:51 PM
