How do you remove the headliner? (urgent)
Old Dec 15, 2010 | 10:23 AM
Default Re: How do you remove the headliner? (urgent)
Thanks for the info guys, I will be removing mine sometime soon to recover it and soime pillars.
Steve - what do you mean when you say, 'sail panel trim'?
Any other tips I should know about removing it, or just start somewhere and pull?
Old Dec 15, 2010 | 12:08 PM
bluecoupe's Avatar
John, the sail panels are the areas behind the rear side windows and to the right and left of the rear window. The culprits that create the blindspots!
Old Dec 15, 2010 | 02:21 PM
Ahh, I see. Well Steve, any tips for me?
Old Dec 15, 2010 | 03:15 PM
velociabstract's Avatar
The service manual is a good resource to know the sequence. I did it this way:
a.- Remove the sun visors (2 screws for each)
b.- Remove mirror from the base glued to the glass (pray then pull straight down)
c.- Remove the plastic over the interior lights (popsicle stick works)
d.- Remove the 2 screws holding the interior light assembly on
e.- Unplug the 2 wire conections (interior lights and garage door opener)
f.- Remove the side pillars (I inserted 2 wooden kitchen utensils from the top and pulled rather hard towards the interior, they snap off)
g.- Pull the rear sail trim panels down until one plastic clip lets loose
h.- Pull the center of the headliner push pin down (by the rear glass) and remove the trim pin
i.- Move the seats all the way front and recline them all the way back
j.- Gently pull on the perimeter and it will come down
k.- I don't know how I got it out the passenger door but thats where it comes out, take your time so you don't damage the corners. It's real tight and won't come out if the angle isn't just right. You can't come out diagonally or backwards or any other way except the installed orientation, front slightly diagonally down. Good luck!
l.- I forgot to remove the garage door opener but it was unplugged and come out with the headliner.
Everyone feel free to add tips and hints.
Les
Old Dec 15, 2010 | 06:55 PM
bluecoupe's Avatar
John, I think Les covered everything. I know on the auto sticks, removing the shifter **** gives a little more clearance. It is a very tight fit through the passenger door opening.
Old Dec 16, 2010 | 09:06 AM
Les, thanks a million, I did not realize this would be covered in the service manual.
Steve, thanks for the tip, I may need to remove my manual **** as well.
Old Apr 24, 2011 | 02:35 PM
Lakeview NY's Avatar
I replaced my headliner this weekend went from light gray to black took about four hours.
Old Apr 25, 2011 | 07:29 AM
Lakeview, after having that in the car for a while, would you let us know how you like it? I am going to do mine in CF and worry that going from light gray to nearly black will make the interior look even smaller.....
Old Apr 25, 2011 | 06:14 PM
I love the look the gray just didn't look right.
Old Apr 25, 2011 | 06:50 PM
Beaner's Avatar
With the headliner black, it does make the inside of the car seem smaller. I have had a black headliner for around 3 years now and I would not go back to grey
Old Apr 25, 2011 | 06:59 PM
My headliner is still in my office on top of the filing cabinets. Man, I've got to stop spending all my time on the engine and suspension and get it recovered and back in the car. It's time to come clean time folks ....... it's not recovered and in the car because my head hits it with the helmet on. I need a lower seat or I'm just going to mess it up again anyway.
Les
Old Apr 26, 2011 | 08:15 PM
You don't need to remove the mirror or shift ****. Fold seats foward put passanger window down and take out side door. WORK SMARTER NOT HARDER
Old Aug 10, 2013 | 01:16 PM
S. Artee's Avatar
Default
Thanks for the list, helped a bunch. I found that the rear tabs of the liner have small indentations which allows them to fold, clearing the quarter window seal. After that it literally slips right out!
Les
Old Aug 10, 2013 | 02:39 PM
From a former write-up :
Gee - this was a dumb post - please ignore.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
onehundred80
Aug 6, 2016 12:03 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
