Dash Trim paint removal
Old Jun 25, 2015 | 08:23 PM
Trenzman's Avatar
Default Dash Trim paint removal
Someone on here has removed the black rubbery paint on the dash trim above the guages. What did you use to get it off? What my finger is pointing too...
Old Jun 25, 2015 | 08:44 PM
bluecoupe's Avatar
Default Re: Dash Trim paint removal
I used a small amount of paint thinner on a micro fibre towel. It worked very quickly as I recall.
Old Jun 26, 2015 | 12:54 PM
Thornh's Avatar
I am looking to remove the paint from that area as well, do you recall whether you used enamel or lacquer thinner?
Old Jun 26, 2015 | 04:41 PM
I honk that somewhere here someone used brake fluid to strip the paint and it did a nice job.
Check it out before you try though, I could be wrong.
Old Jun 26, 2015 | 05:30 PM
Trenzman's Avatar
i know 180 that its glossy smooth black under it, I would hate to dull it usung the wrong stuff hopefully someone that actually got it off will chime in. I was thinking about using the mr clean pad that you can scrub the walls with. if its ok on wall paint should work ok on the plastic.
Old Jun 26, 2015 | 06:02 PM
bluecoupe's Avatar
Low odor Varsol, I thought about laquer thinners but was afraid it would damage the plastic.
Old Jun 26, 2015 | 08:24 PM
I think that somewhere here someone used brake fluid to strip the paint and it did a nice job.
I found the post, it was written by ChuckNorris, here it is.
LE Cross
Oct 17, 2016 06:35 AM
Buchacho
Aug 21, 2015 04:56 PM
flame
Aug 19, 2015 04:06 PM
XFIRED-TX
Aug 8, 2015 07:38 PM
2004_
Jul 11, 2015 03:14 PM
