Passenger window is faulty
Old Jun 18, 2018 | 09:18 PM
GreersCrossfire's Avatar
Default Passenger window is faulty
Hey there Crossfire folks! Our passenger window has been acting up and not going up every time, so we took it to a dealer. They said it's a module that needs to be changed...parts/labor $2500. Anybody had a similar issue and does this cost sound about right? Thanks!!
Old Jun 18, 2018 | 09:37 PM
Default Re: Passenger window is faulty
Could be the body control module, I guess :
Old Jun 18, 2018 | 10:16 PM
thank you! i read a similar thread and the BCM was the issue. on that thread, they said their cost was only $1000. wow what a big difference! we're picking up the car from the dealer and will see if we can get it fixed elsewhere.
Old Jun 18, 2018 | 10:30 PM
I would be curious how they diagnosed that the switch isn't bad...
Old Jun 19, 2018 | 07:28 AM
Is it a coupe or a roadster? I would take off the door liner and see the window mechanism work. Maybe you can see the reason.
Old Jun 19, 2018 | 02:32 PM
Like hell it's the BCM. This is TYPICAL dealer troubleshooting, 'Oh, there is an expensive module and since I know nothing about electronics, I'm sure that's the problem. It can't be a motor or a switch or a corroded connection."
As for the cost, keep in mind a new lock cylinder for the ignition is around $200, and it takes no more than 2 hours to change - but every time someone gets one replaced, it runs $850-1200. Dealers are the LAST place you take ANY car.
Old Jun 19, 2018 | 04:17 PM
Larry Hitze's Avatar
Pizza is there a specific body control module on this car or is it several modules by different names? Thanks trying to help out a Facebook member
Buffalo-Lax35
Jul 15, 2015 05:12 PM
shedman
Jan 30, 2012 03:47 PM
Mr. Burns
Jul 28, 2010 03:06 PM
kumar
Apr 16, 2005 11:08 PM
tbbucs5566
Jun 20, 2004 12:16 PM
