Red light stays on even when the top is closed
Old Jan 28, 2020 | 09:46 PM
iccubus's Avatar
Default Red light stays on even when the top is closed
Chrysler dealer is no help! I had the d ring closure mechanism replaced but now the PTCM won't stop beeping when I try to drive the beast! Any help out there?
Old Jan 28, 2020 | 10:32 PM
Shamrock's Avatar
Default Re: Red light stays on even when the top is closed
Best guess is that the rear bow is not latched. Try latching it manually with the top tool. If it is latched, probably a problem with the latch mechanism. I believe there is a micro switch that indicates that the rear bow is latched. I'll look at the wiring diagrams tomorrow and post some more info.
Old Jan 28, 2020 | 10:50 PM
Smile Re: Red light stays on even when the top is closed
The OEM top tool is for the tonneau latch, not the bow latch.
For that you need a 6 mm hex, or one of the MB tools that has both on it.
Old Jan 29, 2020 | 09:27 AM
Shamrock's Avatar
You are correct. I have the non-OEM and didn't think about the OEM.
Old Jan 29, 2020 | 09:51 AM
KeithTexas's Avatar
I actually think it will stop beeping after about 5 minutes of driving. At least that was my experience when I was having issues a year or so ago. But it's pretty hard to drive with the beeping going on.
OK, that aside....Step 1: let's not assume that the Chrysler dealer that you took your beauty to knows much about the Crossfire.
Step 2: Pizzaguy would probably suggest that you try to recalibrate or retrain the TCM by manually raising and lowering the top with the engine running. Get the tool with the wrench on one end and the hex key on the other end. It's still on eBay for under $30. Manually raise and lower it three times, if I remember right.
Here's the video for manually raising it, if you need it:
Step 3: Recheck the switch in the railing in the top just above the passenger's head. You can see it better if you raise the top a little and stop it. Have someone else handy to help hold everything.
Step 4: Recheck the switch in the trunk divider to be sure that it is engaging. Maybe that should be step 3 since it's easy to check.
Also, most folks would want more info on the problem. Whatever you can share about it might help.
Do you hear the trunk locking when you try to raise or lower the top?
Is the top working at all?
Any water in the trunk?
Is it still at the Chrysler dealer?
Old Jan 29, 2020 | 01:29 PM
What Keith Said!
Old Jan 29, 2020 | 06:17 PM
iccubus's Avatar
Top works fine. No water or anything else I could check. I'm going to try driving it as suggested for five minutes. If I go deaf it is your guy's fault! After sitting a few minutes with the top up the light goes out while in my carport.
Old Feb 3, 2020 | 06:22 PM
iccubus's Avatar
The beeping does stop after a few minutes but the red light says on....no blinking. With the radio on loud I can live with the issue for now until I can get another body to try the manual raising and lowering the top. In SoCal it never rains! Right.
Old Feb 6, 2020 | 07:22 AM
Here is the best website (MHO) to purchase the M-B Emergency Soft Top Retractor Tool.
phyla
May 4, 2018 06:08 PM
ashkanmo
Apr 27, 2016 02:31 PM
daiglels
Feb 28, 2012 06:55 PM
Trixie
Nov 21, 2010 12:13 PM
user 8202
Oct 25, 2009 12:10 AM
