Roadster Drivers Seat
Old Jan 16, 2021 | 12:15 AM
Jack G's Avatar
Default Roadster Drivers Seat
Drivers seat forward and back switch does not work. Switch clicks once in forward switch position. Vertical and tilt motions work.
This seems to be a switch related problem. If so is the switch accessible without completely removing the seat?
Old Jan 16, 2021 | 12:22 AM
UrbanE's Avatar
Default Re: Roadster Drivers Seat
The best first step would be to download the manual.
You can locate it in 180’s signature
Old Jan 16, 2021 | 10:14 AM
You must remove the seat.
Old Jan 16, 2021 | 10:20 AM
Jack G's Avatar
Thanks Urban E but where do I find 180's signature?
Old Jan 16, 2021 | 10:34 AM
Same link is my signature
Old Jan 16, 2021 | 12:26 PM
Link to common problem fixes and documentation
Old Jan 16, 2021 | 06:27 PM
No u don't have to remove the seat but it makes it a lot easier,,, if it is your switch i have one it is in good shap no scratches but the front screw hole is broken but still works with a small washer . I want $75 + 20 shipping i am trying to load a picture
Old Jan 16, 2021 | 07:07 PM
both coupe and roadster are the same. you can remove those 3 screws and the handles and just swap the switches
Old Jan 16, 2021 | 09:22 PM
Jack G's Avatar
The switch assembly in the photo looks like a passenger side. Are the switches for both sides interchangeable? As I have indicated the vertical and reclining switches both operate.
If the seat is not removed is removing the side panel with the switches difficult to take out?
Thanks,
Jack
Old Jan 16, 2021 | 10:16 PM
sorry about that u r right it is the pass side I have this .driver's side that i removed the sw were working when i took it out send me say 8 to 10 shipping ans i will send it to u . I had switched my seats left to right (gave me a new seat on the drivers side) https://www.crossfireforum.org/forum...ght=swap+seats then i got a new seat pass side from a roadster put it in the dr side of my V8 coupe sent u a pm
pjs626
Dec 10, 2017 08:48 PM
Bigtim
Jun 8, 2017 09:02 AM
awdspyder98
Jan 3, 2014 07:11 PM
ronperreault
Jul 15, 2009 08:10 PM
Midwest Muscle
Oct 24, 2007 10:32 AM
